Results 11 to 20 of 29
Thread: Strange LXV starting problem.
06-01-2009, 07:25 PM #11
vapor lock sounds like. problem with skiers choice and several other boats are that the fuel pump is in the engine compartment and gets too hot. ethanol lowers the boiling point of gas to something like 150deg. doesn't take much to do it..
adding a second fuel pump inline back toward the tank is one fix that seems to have worked in many other boats. we have just resorted to running the blower and not had any issues since...'06 Supra Launch 20SSV-gone but never forgotten
06-01-2009, 07:25 PM #12Member
- May 2008
- Jacksonville FL
- 42
06-01-2009, 07:26 PM #13Member
- May 2008
- Jacksonville FL
- 42
06-01-2009, 07:29 PM #14
Filter maybe 15 to 20 bucks id expect at your local parts store.
Pump no telling, i dont think they are like car sending units that range from 100 to 200. Have to get some of the other senior guys here that have done these replacements to help ya on that one.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-01-2009, 10:59 PM #15Member
- May 2008
- Jacksonville FL
- 42
thanks again.
06-02-2009, 01:52 AM #16
Definitely sounds like vapor lock. Was it a hot day? This has happened to my brother on his fuel injected Tige 24V and I have read about it happening to others many times. Run your blower all the time when it's hot, and open the hatch for a bit if you are going to park for a while.
I hear there is a quick fix while on the water that involves placing a wet towel over the fuel pump to help cool it off and liquefy the fuel again.
AlAl
06-02-2009, 05:04 PM #17Member
- May 2008
- Jacksonville FL
- 42
I'm hoping it was vapor lock, because that would mean my fuel pump is working normal for these boats.
It was a very warm day ~90, but I have had this boat for 3 years now and put about 80 hours on it and driven it during many 100 degree days and it has never done this before.
06-03-2009, 12:03 AM #18Senior Member
- May 2008
- Seattle, WA
- 104
Yeah, I got slight vapor lock today as our temps were around 90. Pretty warm for this early up here in Seattle. I went to start the boat and it sputtered a little bit then I hit the blower and it seemed to run fine after about 2 minutes of running the blower. It feels like it's starving for fuel.
I'm going out again tomorrow and it actually suppose to be a bit warmer so we'll see if that happens again.
06-03-2009, 12:06 AM #19Senior Member
- May 2008
- Seattle, WA
- 104
06-03-2009, 09:40 AM #20Member
- May 2008
- Jacksonville FL
- 42
My is EFI not a carb. Maybe that makes a difference maybe not.
It seem like its the fuel pump, whether its going bad or just vapor lock, I don't know.
One more piece of information that might help is, when it would run barely, the RPM's would jump up and down on it on without me touching the throttle.
