Results 1 to 10 of 25
Thread: 04 LXV Heater problem?
06-01-2009, 12:57 PM #1Member
- May 2008
- Jacksonville FL
- 42
I'm having a problem with the heater in front of the drivers seat. It has 2 hoses attached to it. I would guess these hoses are to heat up the air coming out of the heater. They are both leaking HOT water really bad. I took both of them off and cut the ends and reconnected them thinking it was a bad connection. That didn't help.
Any opinions?
06-01-2009, 01:10 PM #2
It is just like a car setup. Hot water from the engine is routed thru a small radiator core, a fan blows air across the core and you get the hot air thru the flex hoses and vent. I would suspect that the core has a leak since you said the water lines at tight going into the heat box. MIght get lucky have a radiator repair it or have to replace. It appears one can buy replacements directly from heatercraft.
2014 Mojo Surf
2013 Mojo Sold
2010 LSV Sold
2002 OB LSV Sold
06-01-2009, 01:47 PM #3Senior Member
- May 2008
- Seattle, WA
- 104
What part of the country do you live? It sounds like you have a ruptured heater core?
I replaced mine last year from pulling it out of storage too early while having some warranty work done on it. Don't have the dealership repair it as they will overcharge the hell out of you. I found a complete heater core and housing online for about a $100 new. I can't remember the website but you can search. Or you can remove the complete housing and open up the casing and remove the heater core and bring it to your local auto parts dealer. It should cost no more than $60 for a new one. You remove the heater core by going to the stern (front) of the boat and removing the seat cushion right in front of the driver. It helps to be a medium to smaller stature person since it's a little cramped weezling yourself in there. Me and my buddy are both big guys and we managed but it would of been easier if we had a smaller friend help. But neverless anybody should be able to do it. You unscrew the housing from about 8-10 points and remove the hosing from both sides. Some water will come out of course but that is to be expected.
It's really a easy do it yourself fix. I believe my local Moomba/Supra dealership quoted me $350. Ha, what a joke.
06-01-2009, 02:44 PM #4Member
- May 2008
- Jacksonville FL
- 42
Thanks for the information.
I try that.
06-01-2009, 03:38 PM #5Senior Member
- May 2008
- Seattle, WA
- 104
Are you seeing steam from the vents when the heater is turned on?
06-01-2009, 03:44 PM #6Member
- May 2008
- Jacksonville FL
- 42
Yes but only for a short time after i turn it on, until it clears it out I guess.
BUT stream almost constantly comes out even when the heater is not on.
I was roasting in the drivers seat the whole time between the 95 degree temp and the stream coming from under the dash.
06-01-2009, 04:07 PM #7Senior Member
- May 2008
- Seattle, WA
- 104
06-01-2009, 04:14 PM #8Member
- May 2008
- Jacksonville FL
- 42
06-01-2009, 09:10 PM #9Sled491 Guest
Freezing water in the core will cause a rupture. For now you can just bypass the heater core by linking the 2 lines, especially if it's in the 90's by you already
06-01-2009, 09:15 PM #10Member
- May 2008
- Jacksonville FL
- 42
