Results 1 to 7 of 7
Thread: Need replacement gauges
05-20-2009, 04:22 AM #1Member
- Oct 2006
- Hong Kong
- 61
Hi I have a 2004 Moomba Mobius LSV
And I need replacement gauges for
Volt Meter
Both Speedometers
Engine Temp
All of them seems to have in accurate readings or jumpy
What are their part numbers? And where should I get them?
05-20-2009, 12:24 PM #2
Etang i'm sure only a dealer would have the part numbers unless by a miracle someone has them lying around which is seriously doubt. If you want oem stuff you'll probably have to go to your dealer or you could buy these if they'll work.
05-20-2009, 12:30 PM #3
I have dealt with them before. They are a first class outfit. You can call them on the phone and they are very helpful. I had a situation where they shipped the wrong material for my interior. The sample they sent had been an exact match so it didn't make sense. While on a portable phone one of the employees went out to the warehouse and examined the roll. We determined the roll itself had been mismarked. They shipped the right stuff and didn't even want the wrong stuff back. I still have it if anyone wants several yards of mismatched light grey vinyl.
05-20-2009, 12:44 PM #4
Before you go to the effort and expense of changing out all those gauges, you may want to check the connections for a short somewhere. Might save you time and money. I've had a periodic issue with my tach and temp guage doing the same thing. Just a thought.
05-21-2009, 03:28 AM #5Member
- Oct 2006
- Hong Kong
- 61
05-21-2009, 07:59 AM #6
If it is anything like my 99 Mobius, the culprit may be the gauge controller. For mine it was an MDC 1600 . Look at the back of the gauges and follow the wires to see if they all lead to a black box on the bulkehead by your feet or ? If so then there is probably also a separate wiring harness coming out of that box with wires going to all of the different sensors/sending-units.
If there is a controller, you might be able to get troubleshooting instructions from the manufacturer. I was able to get them from Medallion. If it is the controller - you can buy directly from the mfg and save hundreds over having the dealer do it.
Good luck.
DaveIf you believe something to be true, it will be - in it's consequences.
05-22-2009, 01:48 PM #7Senior Member
- Apr 2008
- Knoxville
- 175
Call Jim Jackson at viper customs at 865-388-4096 he should have what your looking for and will be cheaper tell him you saw it on this site to get the best deal. Hope this helps
