Results 1 to 10 of 14
Thread: 2001-2005 LS owners - question
05-17-2009, 11:58 AM #1Senior Member
- Aug 2007
- Nashville, TN
- 257
Can anyone tell me where the stock ballast bags go in the 2001-2005 OB LS and Mobius LS? My LS has no ballast and I want to add a little ballast and am not sure where to put it. I assume the natural place to start is under the rear bench seat, but I'm having a hard time finding a bag that would fit well back there. It's not a very tall space. If it goes there, does anyone know what brand/size? I've seen a few people talk about putting ballast in the rear ski locker, but I've also heard this is a bad idea.
I'm guessing the other spot is the floor ski locker. Is there a 3rd spot (I assume there is, hence the name gravity 3)?Last edited by volfo; 05-17-2009 at 02:06 PM.
05-18-2009, 01:44 PM #2Member
- May 2008
- Howell, Mi
- 59
You have my attention. I'm thinking about putting some in my 02 also.
Doug
02 Outback LS
Howell, Mi
05-19-2009, 12:41 PM #3
I put a small bag across the floor in the rear ski locker of the outback LS. I only have 2 other bags so I can put them along either side of the engine for wakeboarding or put them in an L shape for surfing with one going across behind the engine in front of the seat and one going along the port side on the floor. I think your seat is the one that has an "up" position so you can fit a bag underneath it. Lots of folks do that. Just need one that is kind of long but not real thick. You might not be able to fill it up all the way either.
05-19-2009, 05:41 PM #4Junior Member
- Jan 2005
- 29
I have a Mobius LS '05. It came will ballast under the back seat. It is not a bag, but hard plastic. It adds 500 to the back. I then add 300 to the ski locker(think long and skinny for the bag). Once I add in my large riding partners(they range from 225 - 300lbs), we end up with a great wake.
05-19-2009, 11:37 PM #5Senior Member
- Aug 2007
- Nashville, TN
- 257
thanks Kane and Moby. that helps some.
05-27-2009, 11:43 PM #6Senior Member
- Jun 2006
- 194
My 2004 LS has a hard tank under the rear seat and a bag in the front locker, I was under the impression each one holds some where around 400 lbs.
06-10-2009, 11:49 PM #7Senior Member
- Aug 2007
- Nashville, TN
- 257
mimoomba, how do you like your monster tower? I'm very happy with mine this year. I got the new monster tower cargo bimini and installed it and love that.
Because you said you were interested, here is what I think i've decided on the ballast after getting help from jason at wakemakers and ed g. I'm going to go flyhigh and get 2 v drive bags that are 16 by 16 by 42. The space under teh rear seat is about 8 by 16 by 80. So, I can only fill them halfway up, but that supposedly isn't a problem at all. That will give 400 pounds or so. Then, I'm putting a fly tubesac in the ski locker, about 350 pounds. Having the 2 v drive bags would allow me to pull them out of that compartment if I really want a ton of weight and fill them giving me 800 pounds out of them. I'm going to try it.
06-11-2009, 12:21 AM #8
Be sure to let us know how it works out. The more pics the better.
06-11-2009, 11:13 AM #9Member
- May 2008
- Howell, Mi
- 59
Volfo
Luv the tower and thanks again for your help with it! Now if the weather will just warm up around here so we can get some use out of it.
I'll be interested in how the sacs work for you. Keep us posted.Doug
02 Outback LS
Howell, Mi
06-11-2009, 12:11 PM #10Junior Member
- Sep 2008
- San Angelo, TX
- 4
I have a 02 LS, and here is what I did. I have a bag underneath the back seat, not for sure what kind, but it is 500lbs. I also put another 600 lbs in the very back ski locker. I used front end tractor weights, rhino-lined them, and stuck them in there. I still have room for my jackets, and other misc. stuff. It works great. A little bit more difficult to plane out, but the wake is epic......
