Results 1 to 3 of 3
Thread: steering cable lifespan
05-10-2009, 06:06 PM #1Junior Member
- May 2009
- 1
I replaced the steering cable on my 02 mobius less than one year ago and the first trip out this year cable is stiff again. Is this to be expected? Would cable have any warranty at all?
05-10-2009, 07:32 PM #2Junior Member
- Apr 2009
- 18
Sounds like you may have a routing/binding issue. Cables should last ten +years if they are not exposed to the elements.I you bought it locally I would take it back and request another one.
05-10-2009, 09:43 PM #3Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
You should try to trace down the problem that is causing your cable stiffness. Replacing cables is not seeming to fix your problem. Make sure that you cable hasn't rubbed through and allowed water from the bilge in to corrode it.
Keep us posted on the problem and the cure.1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
