Results 1 to 9 of 9
Thread: stereo remote issue
04-29-2009, 09:16 PM #1
stereo remote issue
I'm having an issue with my stereo remote. I have a 2008 Outback with the factory Kenwood unit, plus the factory installed driver's remote. The Kenwood unit also came with the handheld Kenwood remote.
Both remotes work fine when the engine is off. However, 95% of the time that the engine is running, NEITHER the factory installed driver's remote nor the included Kenwood handheld remote will work. The other 5% off the time, the remote will work once or twice shortly after the engine is started, but it never lasts long. This leads me to believe the issue is not with the remotes, since they either both work or both don't work. I'm thinking it has something to do with the current from the alternator once the engine is running, possibly affecting the ground and somehow interfering with the head unit's remote function. And/or I potentially have a faulty head unit. Any other ideas?
This is a chronic issue that has been happening ever since I took delivery last summer. The dealer tried to troubleshoot it twice, to no avail.2008 Outback
04-29-2009, 10:53 PM #2Senior Member
- Feb 2008
- 164
Woah, I'm not Crazy. I thought it was just me not being able to push the buttons correctly. Except, it works for me probably 50-50. It is really annoying when my rider falls and I swing around to pick em up for another round and want to mute or just turn down the volume and I can't get it down So I leap across to the glovebox, pop it and then turn it down manually so I can talk to my rider. If you ever find out what it is, I'm first in line to hear your fix. Oh and I still love my Moomba
Chad
04-30-2009, 11:25 AM #3
My Kenwood does the same thing, but I ordered my boat without a factory radio. I've noticed that sometimes my radio will go into 'protect' mode, causing the remotes to stop working. Is this what is happening to you guys?
04-30-2009, 02:08 PM #4
Is this the kenwood remote or the aeware ??
04-30-2009, 02:09 PM #5
I have the Kenwood remotes.
04-30-2009, 02:48 PM #6
Not sure... what do you mean by 'protect' mode? Does it actually indicate that on the display somehow?
For me both the aeware fixed remote next to the driver and the Kenwood handheld remote exhibit the same behavior. That's why I'm thinking it is not an issue with the remote itself... unless of course the aeware remote is bad, and it is somehow affecting any remote control function in the head unit.2008 Outback
04-30-2009, 06:05 PM #7Member
- Feb 2009
- Central, WA
- 44
What is the model of the handheld remote and what head unit are you using it with?
2008 Supra 22V
03-17-2011, 09:12 AM #8Junior Member
- Jun 2010
- SA, TX
- 7
I don't see any updates to this in a while. I am having the same issue, the remotes work great when the boat is off, but not when the boat is running. This applies to both remotes.
I also just installed three amps, tower speakers, and a sub. I didn't replace the head unit now, but did replace it about a year ago with the Kenwood Excelon Kdc-x494. It worked great with the remotes until the recent install.
I have traced the wires, and even replaced the driver remote with a new Kenwood remote. None of this has fixed the problem. Let me know if anyone has an update. Thanks.2005 Mobius LSV
