Results 1 to 10 of 13
Thread: Neoprene repair
04-06-2009, 10:54 AM #1
Neoprene repair
I need to seal a seam in my neopren waders so my boys do't get to cold ( water temp 3 Anyone use Aquaseal? or is there something better for wetsuits etc.
I need the waders to get the docks and hoist in next weekend. I did a trial run and discovered i had sprung a leakA Day at the Lake...Priceless
04-06-2009, 11:28 AM #2
Red Green would use duct tape. Jk
-McMoomba
2008 Outback V
04-06-2009, 11:35 AM #3
I tried that last year with old rubber waders, ( no success with duct tape)Hence the new neoprene waders.
04-06-2009, 11:50 AM #4
I would try some rtv or silicone
04-06-2009, 12:19 PM #5
Doesn't JB Weld fix anything? Can you sew a neoprene patch over the tear? Find an old mouse pad and sew it on.
1998 Mobius
310 HP PCM
SOLD
04-06-2009, 01:08 PM #6Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
04-06-2009, 08:06 PM #7Sled491 Guest
How did you manage to ruin a second pair? My Neopren waders came with a standard inflatable repair kit. So you should be able to repair it with inner tube repair cement and a rubber patch
04-06-2009, 09:11 PM #8
Brad, thanks for the video. the seam sealer is for rubber, that would have worked last year. They went out in the trash. Seam sealer and aqua sealer are made by the same company so the video proved the product worked and if they made one for neoprene then i think i am good to go.
http://www.joediveramerica.com/Merch...iliate=froogle
Sled, no big holes or rips just seapage through the crotch area around the stiching and seams. Last years waders were REALLY OLD. I must have tossed the repair kit withh the box if it was in it at all.A Day at the Lake...Priceless
04-06-2009, 09:15 PM #9Sled491 Guest
JV, maybe I'd try the same seam repair or tape they use for tents seeing as you just talking a bad seam.
04-07-2009, 10:38 AM #10Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
I have used Aqua Sealer before on the neoprene for a dry suit. It worked fine and I had no problems.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
