Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Do you have any pictures of it taken apart? How does the seat come off of that sliding mount? Ive taken then seat out before but i took it off with the sliding thing still on the bottom. dont remember seeing a way to seperate the two.
  2. #22
    Mar 2008
    Vancouver WA
    Pull your seat cushion out and you will see the bolts. Just remove the nuts and washers, and the carrage bolts will remain in the slide. You may have to hold the carrage bolts in place to keep them from spinning.
    Then take the small access panel off the front of the fiberglass seat base to access the slide bolts.
    PWI as usual...
  3. #23
    Quote Originally Posted by newty View Post
    i was unaware you could remove the seat cushion from the frame, does it just pull up?
  4. #24
    Mine's just velcroed in there.
    Mar 2008
    Vancouver WA
    I know the newer seats are a little different but I'm pretty sure they pop out.
    PWI as usual...
  6. #26
    Ok well I will look at that when I get home wednesday. I never even tried cause I figure they were permanently attached. didnt want to break anything.
  7. #27
    Feb 2010
    Canton, Ga / Lake Lanier
    Has anyone else tried this? I want to do it too.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  8. #28
    Feb 2012
    Im in the same boat, has anyone done this on a new boat?
    Current ride: 2011 LSV
    Old ride: 2005 LSV
  9. #29
    May 2011
    Fort Worth
    Brilliant...I wish I was smart
    '08 Mobius LS
  10. #30
    Feb 2010
    I'll be getting the parts to do this soon and will try to post a write up about it
    Tow Rig:
