Results 1 to 10 of 13
Thread: about to buy
    Jan 2004
    houston texas
    Default about to buy
    Hey my current boat is a 1998 Horizon 200 Four Winns. I'm 16 and im really into wakeboarding and skiing. My parents are most likely going to buy a 2003 Mobius LSV with factory ballast, tower, and Hydraulic wake plate. (Never been off the showroom floor) But my dad is having trouble adjusting to the fact that the Mobius sits MUCH lower in the water and doesn't have the ''Deep V'' hull configuration to cut through the chop. We've never owned a ''ski'' boat before. Could anyone help us out and tell us how yall's boats handle in choppy water? We've been told the wake plate will help smooth the ride out in choppy water when adjusted properly. Is this true? How does your Mobius LSV hand the chop? How do any other Moombas handle the chop?
    Thanks so much
    Tanner Vickers
    Charge hard, stay stoked!
    You never stop feeling the pull
    WAKE up
    Charge hard. Stay stoked.
    Jan 2004
    houston texas
    Default Replying to Topic 'about to buy'
    Also I have heard that inboard boats like these don't back up very easily unless going in a straight line. Is this true? Is it hard to handle these boats while reversing left or right? I'm so stoked about getting our new boat I just have some questions.
    WAKE up
    Jan 2004
    houston texas
    Also, how's the wake behind these things, pretty stoked out? Anybody have a LSV that can talk to me would be a GREAT help.
    again... lol
    WAKE up
    Aug 2002
    Bismarck, NorthDakota
    I have a Mobius d-drive, with weight I can get a good wake, next year I will be getting a new LSV because I have been told and I know the wake will be much better (bigger).
    Backing up inboards is tricky no doubt about it. Some times I need to go forward to straighten out and then back up again. Inboards straighten out very fast with a little forward nudge.
    They are not rough water boats. They do handle minor chop ok and the wakeplate should help. If I end up in some real rough water I end up driving slow to keep the front end in the air, doesn't happen often, if the water is that rough I stay home.
    Good luck, you should fully enjoy boarding behind it.
    CHeck out the rackjack if you will be lowering the tower.
    www.wakezone.biz
    Bruce Fuerstenberg
    Jan 2003
    Minnesota and Wisconsin
    Ditto.
    I own a 1999 Mobius. Backing up is an art. Mot osf the time it seems that no matter what you do with the steering wheel the back of the boat wants to go to the starboard. That can be pertty handy if you are pulling up to a dock that is on your starboard. If you nose with the stern out a bit and then turn the wheel and hit reverse you almost go straight sideways into the dock. Do not expect the same behavior as yo get from an outboard or a stern drive. This adjustment is far outweighed by the performance of the boat.
    Freeboard is a different issue. First you have to realize that most owners of AWSA appoved ski boats are not all that interested in rough water travel. However, the freeboard off the bow on my boat is a real issue for me. Occasionally I think I might like to put in on the St. Croix river, but with the large cruiser wakes out there it will never happen (that and I don't trust rivers).
    I run into trouble when I hook back to pick up a fallen skier. In our old runabout I used to slow down quickly, do a tight button hook and then right to the skier. This requires cutting through your own failrly large wake at low speed. If I do this wrong I can get 50 gallons over the bow in an instant. Again - this is just an adjustment. If you avoid going into the wake perpendicular the boat will ride up the wave and no problems. Or if you give a little throttle just as you hit the wake, no problem. This problem is probably enhanced because you can make such a tight turn back to the skier.
    I had or used a conventional run about for almost 20 year and the Mobius for 3 now. Despite these issues I would NEVER go back to any type of out-drive. For my purposes I would not go witha V-Drive either (although I have never been in one). The physics of the mid-engine boat just make too much sense to an old slalom skier like myself.
    Enjoy
    Dave
    http://bensonwdby.home.comcast.net/
    Jan 2004
    houston texas
    We boat in canyon lake texas and its a fairly big lake and during the summer mid day when everybodys out it can get a choppy. Will we have to constantly worry about water comming over the front? I'm starting to worry a lot about the ''Rough ride.''
    WAKE up
    Apr 2003
    Powhatan, VA
    Today's wakeboard boats might be as good or better than the Four Winns.
    Maybe the best bet is to try one out on a choppy day.
    You can a life jacket out while motoring, then practice retrieving it.
    That will tell you a lot.
    The manipulation of the boat at the dock is much different, like dave says, but its doable. I think you just have to play with it and relearn.
    Like docking. I approach at a 30 degree angle ( right front of the boat to the dock ). Then, while still moving forward, go to reverse. Don't even need to spin the wheel, cause the stern will walk right to the dock and voila', your laying right against it.
    Oct 2003
    epsom new hampshire
    I have a 2002 mobius lsv and have used on large lake on a weekend when the waves are 2-3 feet.It gives you a pounding but handles good under 22 mph.The lsv's bow is out of the water enough that its a pretty dry ride.I had a 2001 kamberra that was much better in rough chop.I have a new mobius xlv on order which I understand to be a great wakeboard boat and also a big lake boat when its to rough to wakeboard.The lsv drives and handles great.If you were in rough water alot the time I would look for a mobius V or look at the new XLV.Just my opinion.Good luck, all three are great boats
    Jan 2004
    houston texas
    Thanks for all the replies it'll help me a lot. If anyone else has anything else to say about this, PLEASE POST IT!
    WAKE up
    Oct 2003
    Wisconsin
    It is true about docking your v-drive. the boats will go slitley to starboard as you go in reverse. With the rudder being behind the prop they are unable to stear but the main thing is that the prop is in a fixed position. An IO or outboard, the prop turns with the stearing forcing the boat in that direction. But with a little practice you will forget about the old ways of driving. I have a new LSV on order and am waiting to test it in some medium size waves.
    BlueMoomba
