Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: new dash lights
    Atlanta via Pittsburgh
    Default new dash lights
    I replaced all the dash lights with LED's from superbrightleds.com
    I used the WLED-x6 LED blue. It was pretty easy. You just have to reach up under the dash and remove the black bulb holder, and swap the bulbs. The big ones take 2 bulbs the small ones only 1.
    Go Boat
    May 2007
    Richmond, VA
    Chilly - So this is a direct swap? No modification required? Just buy the bulb, remove the old, and replace? This I can do! Pretty nice. Thanks. - Deerfield
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Calgary Alta Canada
    Smile
    That looks really cool and shouldn't be too hard to do. How many gauges were you able to change out and does this include PP guage?My boat is buried in snow so theres no way to look yet ,but would be definetely interested when it warms up,if it ever does.
    Feb 2008
    Haslet Tx
    Thumbs up
    chillyx , Can you tell me exsactly what you orderd im going to order the same for my LSV if they have my color that looks great !
    I Think MOOMBA is Addicting
    Feb 2008
    Haslet Tx
    Looks like you have the gage all the way out to put these in. I orderd 10 WLED-x6 amber cause all my other Leds are amber.When i got under dash it look like you have to unscrew the nuts on the bracket OR MAYBE NOT.
    Feb 2008
    Traverse City, MI
    Very cool indeed, I'm definately going to do the blue on my gauges, thanks for the idea/part number!
    2013 Outback V
    Default Part number
    The part number for superbrightleds.com is WLED-x6 LED. I was able to do all the gauges except PP and our depth finder because it was already built in. I did take out one of the gauges because originally I was going to rearrange them, but that involved cutting wires and splicing them back together so I decided against it. I did the rest by just using a pair of tiny pliers the grab the back of the bulb housing. Its just a twist and pull. You have to be a contortionist to get to them but it can be done.
    Go Boat
    Default Other lights
    I did add some other accent lights to replace the courtesy lights in the rear. I also added two lights up front and two lights over the speakers in the rear. I'll try to get some better pictures later
    Go Boat
    Feb 2008
    Haslet Tx
    Well orderd my led's got them in today and installed them alot easier thnan i thought thanks for the tip !
    Oct 2007
    Chillyx - Very nice. I have been wanting to add blue LEDs to my interior, but was actually hesistating due to the dash light colors. My 06 Mobius LSV has no interior lights. I plan to add some to the the cup holders, below the dash and if I get the nerve to drill holes into the fiberglasss around the interior. Any recommendations on what products to by from superbrightleds.com?
