Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 96
  1. #31
    Aug 2006
    Salt Lake City
    I get all 3 sometimes when Riding is involved...
    Time is the worst factor these days.. I could overcome the other two..
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
  2. #32
    Quote Originally Posted by newty View Post
    Three things rarely found together... Motivation, weather, and time!
    I think that's what Socrates said about his Moomba-- our was it Confucius?
    Apr 2007
    Las Vegas, Nevada
    Newty and Moombadaze--
    OK help me out here. I went out and purchased the new watermaster(Orbit) vlave. I did what you explained in your pictures. I put the pump in the water and turned it on and nothing came out. Not even a drop. Also, just to let you know, I installed the Tsunami 1200GPH pump. I wanted to make sure the pump worked. I took off the valve and there she blows. So I know the pump works. What am I doing wrong?
    Tazz
  4. #34
    Nov 2003
    Land O Lakes, Florida
    Tazz, is it possible the valve is in backwards? they have a little arrow to indacate the direction water should flow.
    I had mine all back together before i saw that little arrow
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  5. #35
    Apr 2007
    Las Vegas, Nevada
    The arrow is pointing in the right direction. I even turned it around to see if that would work and still nothing.
    Here is a stupid question, should the valve be in the horizontal position? Right now, I have the pumpin the bucket of water sitting vertical. The valve is also sitting vertical.
  6. #36
    Nov 2003
    spring is removed in the valve? can you blow air thru the valve?
    dont think vertical would make a difference.
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  7. #37
    Apr 2007
    Las Vegas, Nevada
    yes the spring has been removed.
    Here is another dumb question. Well when I purchased the new valve, it came with the solenoid. The solenoid is 24v. Our boats are 12v. Did you get your solenoid with a 12v of power?
  8. #38
    Nov 2003
    1" or 3/4" valve?
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  9. #39
    Apr 2007
    Las Vegas, Nevada
    Yes I can blow air through the valve. I even removed the solenoid to see if it was causing a restriction.
  10. #40
    Apr 2007
    Las Vegas, Nevada
    3/4" valve.
