Results 1 to 7 of 7
    Sep 2008
    Claremore Okla
    Default Battery Isolator
    I will be installing a battery isolation relay, for auxillary battery. Any input?
    Apr 2008
    California
    Definately go with the Blue Seas 7610 ACR setup. It does not have the issues of a regular iso and has full circuit protection. I installed the 7650 Which includes their batt switch after using regular Iso's on all my previous boats and it's basically worry free.
    Blue Sea 7610 ACR
    Sep 2008
    Claremore Okla
    Blue Sea 7610 ACR
    Thanks for info. What problems did you have with reg isolation relay
    Apr 2008
    California
    First off they can burn up without warning, not disconnect, most std iso have a slight drain at all times as well.
    Here's the Blue Sea 7650 on mine:
    Apr 2007
    Las Vegas, Nevada
    Razz,
    How will that work with dual batteries? Will I need two of them?
    Apr 2008
    California
    Here's the docs that show the install instructions.
    The Switch: 5511e Switch
    The ACR: 7610 ACR
    Mar 2003
    s.e. washington state
    Excellent install Razz.
