Results 1 to 10 of 11
02-08-2009, 06:24 PM #1Senior Member
- Jun 2008
- 143
NEED HELP - 2008 Outback no power to accessory switches
I am in the middle of a stereo upgrade and when I connected the battery today to test everything, I had no power to my accessory switches. What am I overlooking? The gauges pop on with the key turn, but still nothing to the switches. Is there a master fuse somewhere?
Thanks,
02-08-2009, 10:15 PM #2Reese350 Guest
Check the master down by the battery. Look for the red reset button.
02-08-2009, 10:35 PM #3Brian Raymond Guest
The red button will pop the breaker when pushed, when this is pushed, a small black lever will kick out. Push the lever back up and it will reset the breaker. Hope this helps, keep us posted. Brian Raymond
02-08-2009, 11:00 PM #4Senior Member
- Sep 2008
- Claremore Okla
- 202
Make sure the circuit card is pushed in behind the switches
02-08-2009, 11:27 PM #5Senior Member
- Jun 2008
- 143
Thanks guys, the project will be on hold until next weekend, but I will keep you posted.
02-08-2009, 11:44 PM #6Senior Member
- Jun 2008
- 143
Do I risk any equipment damage if I bypass the circuit breaker and fuse to continue to diagnose?
02-09-2009, 12:20 PM #7
Wow! That would be one awesome stereo.
02-09-2009, 05:18 PM #8Senior Member
- Jun 2008
- 143
Ok, problem fixed, but I am embarrassed. Thanks for helping me focus on the circuit breaker. Yesterday was a long day, and seeing that the wire coming out of the circuit breaker for power supply was coated in black conduit with a ring of black electrical tape around it at the terminal ring, I assumed Skier's Choice was telling me this was a ground. It was not
The system is loud, and I love my WS420 so far.
Thanks guys!
J
02-15-2009, 10:57 PM #9Senior Member
- Jun 2008
- 143
I have a new problem. It seems I am overdrawing the system when I hook everything up. I can can not run the stereo for longer than a few seconds before it turns off, nor can I run more than 3 accessory switches for a few seconds. The breaker doesn't neccessarily trip each time, I just lose power. The weird thing is that whenever I remove all the stereo wires, and run only the main battery termianls and the fuse box/circuit breaker wires to the primary battery, I still lose power. Any ideas? Low battery(x 2), loose fuse, bad grounds(to the negative terminals).... For example, when I turn the courtesy light switch, they come on at the beginning and immediately go out everytime I flip the switch...
I am so frustrated, thanks in advance. Sometimes I hate my hobbies
02-16-2009, 10:02 AM #10Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
