Results 1 to 10 of 15
Thread: heater install
    Feb 2004
    Default heater install
    installing a heater in 03 mob V. 320hp tbi. couple of questions can someone confirm that the plug that I should be removing on the intake manifold is on the right if I am facing the rear of the boat and is removed with an allen wrench. Also where is the best place to ground heater? thanks
    Jun 2002
    Lake Mayo NC
    Default Replying to Topic 'heater install'
    I'll be doing mine this weekend, I have a d-drive but I'll post results on Mon (hopefully)
    Aug 2002
    Bismarck, NorthDakota
    I have a d-drive, I installed my heater awhile ago but here is what I remember.
    The instructions had me remove a plug on the water pump and the other was on the drivers side of the engine, below the manifold. I had to buy a "special" square socket. The plug was smaller than a 3/8 ratchet drive but bigger than a 1/4, Iguess that makes it a 5/16 square drive.
    Bruce Fuerstenberg
    Aug 2002
    Maryville, Tn.
    The best routing for your heater is the square plug fitting in the circulation pump, and the square plug fitting in the cyl. head between #6&#8 cyls. The square fitting is metric and not easily found, if you have a sacrificial 6" 3/8" extension and a bench grinder, this is your best bet. Let me know how the install went. Brian Raymond
    Jun 2002
    Lake Mayo NC
    When we did mine this weekend, there was a plug on the water pump that had a square lug we just used a regular wrench to get that. On the engine (d-drive TBI) there was a plug on the drivers side at the same location as the temp sensor (which is on the pass side) that had a hex opening not a square.
    Dec 2006
    Tigard, Oregon
    Quote Originally Posted by Brian Raymond View Post
    Hi Brian,
    I am about to install a heater on my 2006 LSV with the 325HP engine. Could you please tell me the best place to connect the inlet and outlet hose, or is it the same as above?
    Thanks,
    Al
    Al
    Eugene OR
    Al,
    I would think they you have the ports on the engine but they just are blocked off right now. I have attached two photo's from my heater hoses. Please note this is for a V-drive 325hp.
    From this photo you can see the two black hoses zip tied together next to the carpet. The first hose goes up into the block and is cut off a little by the support bar on the right side of the photo.
    This second photo is the other hose going into the back of the engine (back of the engine is at the aft of the boat). It is the smaller black hose that comes into the photo in about the middle of the photo. You can also see the impller pump at the bottom of the photo that is about 3/4 of the way to the right of the photo.
    Sorry these are just photo's i had. If you need better ones i should be able to get them too you this weekend. I can also put in arrows if that will help.
    Dec 2006
    Tigard, Oregon
    Thanks Jester, that helps. You don't have any shut off valves at the block? What do you plan to do if the hose develops a crack and water starts gushing out?
    Al
    Eugene OR
    If the hose gets a crack then i hope my bulge pump works. Also another reason to keep duct tape on the boat . I have been thinking of putting a shutoff valve in but have not made it that far. Right now since it has been dropping to the mid 30's at night i pull the hoses to the heater and blow them out. I was told that the heater will be the first thing to go if it gets too cold out.
    Eugene OR
    Al, Also the hoses are at the top of the block so the amount of water that comes out when the engine is not running is not that much.
  1. Heater install in my '07 LSV
    By csmsk in forum General Chat
    Last Post: 10-25-2009, 02:21 PM
  2. Heater
    By mattjj23 in forum General Chat
    Last Post: 03-15-2007, 07:54 PM
  3. heater
    By 04moblsv in forum General Chat
    Last Post: 03-05-2006, 10:59 PM
  4. heater
    By ouimguy in forum Sales & Information
    Last Post: 01-25-2005, 02:24 PM
  5. boat heater
    By Keaton in forum Service & Repair
    Last Post: 01-19-2005, 01:57 PM
