12-17-2008, 02:14 PM #1
Quick Winterization drain plug valves
I remember a post on these.............but i cant find it. Any thoughts?
12-17-2008, 03:50 PM #2Senior Member
- Aug 2008
- Knoxville, TN
- 208
https://forum.moomba.com/showthread.php?t=6960
Check those out I like the first one.
I ended up just going to the hardware store and I found the same size brass screws that were in my engine blocks except they were in a thumb screw version
No tools required but I use a pair of channel locks to do one last half twist after I tighten with my fingers to make sure they are in there good and snug to prevent leakage.
If I lived where you lived I would at least do what I did or do the easy drain valves that are listed on the first link.RIDE: 2002 Moomba Mobius V
TOW VEHICLE: 2002 Chevy Tahoe Z71
SETUP: 2011 142 Slingshot RECOIL 2011 Slingshot RAD Boots
01-04-2009, 01:34 AM #3Member
- Feb 2007
- 48
Don't forget the exhaust hose
The exhaust headers have a connecting hose to drain those as well.
We kept a single small wrench for removing the drain plugs every trip during the winter, one plug located on the bottom side of each 4 block.
This is from an easy to access 2007 Moomba Outback DD.Stephen
Georgia Tech Water Ski
http://waterski.gatech.edu
Tournament info https://forum.moomba.com/viewtopic.php?t=5296
01-04-2009, 03:48 AM #4
I use brass drain plugs that aren't expensive, easy to drain and won't break or loosen up.
https://forum.moomba.com/showthread....t=drain&page=2
