Results 1 to 10 of 12
Thread: New Decals...
11-13-2008, 03:28 PM #1
New Decals...
So I have ordered the new Mobius Decals to replace mine.
After I remove the old, what should I clean the surface area with before applying new decals?
I use wax as you dry after each use so I am sure there is a bit of a glaze on there I need to remove.
Anyone have any suggestions?Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
11-13-2008, 03:38 PM #2Junior Member
- Aug 2008
- Greenback, Tenn.
- 15
Clean with alcohol,let it dry then use a spray bottle with water to apply the new decals.
11-13-2008, 04:40 PM #3
Thanks Gene.. i was not sure about the wet application as well.
That helps a ton! allows for a little OOPS! I guess a squeegee will be good to have on hand?Brad
2004 Outback sold
11-13-2008, 05:04 PM #4Junior Member
- Aug 2008
- Greenback, Tenn.
- 15
Take a pc. of masking tape place in the center of the decal over the decal masking straight up and down. Then when you get it cetered and level, tape both ends , stand back and make sure its straight and where you want it. At this point have squeegee and water bottle in hand, remove the tape from both ends, then with the tape across the center take the front half first and pull apart the decal from the masking. Be careful not to touch the decal together, then spray the boat and decal with water and apply. Then repeat the back half work the air out as you go. P.S. You may already know how to install decals but this may help someone else down the road...
11-13-2008, 07:25 PM #5Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
02-07-2009, 09:36 PM #6
here is the LSV Nekked. Waiting for more time and no wind to apply the new ones..
What do you think of her Nekked?Brad
2004 Outback sold
02-07-2009, 10:58 PM #7Senior Member
- Oct 2007
- Panama City Florida
- 1,798
Outback,
We use 3M wax and grease remover, it will clean everything off the paint without damage to the paint. You might have to go to an autopaint store to find it.
02-09-2009, 11:29 PM #8Sled491 Guest
04, it looks ok but I like what graphics add to the overall apperance of the boat.
02-09-2009, 11:34 PM #9
02-11-2009, 10:00 AM #10
I have the Streak Graphics to put on her when time and weather permit...
Brad
2004 Outback sold
