Results 1 to 9 of 9
    Default Oil Changer Review - Pela 6000
    I bought the following oil changer:
    http://www.wholesalemarine.com/pc/PE...+Capacity.html
    and used it yesterday to change the oil in my boat and was extremely pleased with the result. See my winterization post for pics of the unit in action.
    I inserted it into the oil drain hose instead of the dipstick tube since I am sure that the oil drain hose will position the extractor tube at the lowest point of the oil pan. After about a dozen pumps, the oil started to flow through the tube. I pumped it a few more times until I could feel positive resistance on the pump handle. I pumped it 3 - 5 more times every few minutes to ensure positive suction continued. It took less than 10 minutes to get all 5 quarts out of the crankcase. No leaks, no mess to clean up, worked great. I would highly recommend this oil extractor.
    Note that I ran the boat on the river for a good 15 minutes to get the oil nice and hot, then drove it onto the trailer, waited 5 - 10 minutes to let it cool a little, then extracted the oil right there at the boat ramp parking lot.
    Aug 2006
    Salt Lake City
    nice..
    I like the cleanliness of it.
    I have a 12v pump.. i learned on the last change last weekend to feed the hose in the drain hose like you did.... but since it has no reservoir and i do it behind the boat out the drain hole... ...still messy.. may have to try one of these...but only about twice a year for me...so... may stay with what I got..
    Nice winterize photos by the way.. now I gotta print that out and go back to the boat to walk through them!!
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Apr 2008
    California
    Al, i too have the Pela 6000 and highly recommend it. I scored mine on eBay for $40 over a year ago from a wholesale auto dude.
    Sep 2005
    Claytor Lake, VA
    http://www.amazon.com/Mityvac-7400-L...5295419&sr=8-1
    Large enough to hold engine, tranny & v-drive fluids. I can drain all 3 without stopping to empty.
    Razz,
    That's what wholesale marine sells it for every day
    Feb 2006
    Birmingham
    Quote Originally Posted by VA LSV View Post
    I use the same one. When I first bought it, I filled it with water 1 quart at a time and marked the quart lines so I can tell how much comes out. I absolutely love this thing. I use it on the cars to drain antifreeze from the radiator, trans fluid and the oil out of the lawn mowers. This thing holds a ton of fluid!!!
    15 Mondo Surf Edition
    02 LSV - Traded In
    Dec 2020
    North Texas
    Hi Al,
    I just purchased on 08 LSV - I am trying to find your posts about winterization. Could you point me in the right direction? Trying to learn how to do my own maintenance on oil, transmission and v drive. You’ve got some great info on here. Thanks in advance!
    2008 Moomba Mobius LSV Gravity Games Edition
    Salt Lake City, Utah
    Scott
    2021 Craz
    1997 Sea Ray 190
    Mar 2021
    3424 Bobcat Drive, Washington, MD 20200
    How much is a synthetic oil change at oil changers?
    When you have to be somewhere and cannot access your bank account, you can transfer money over to your online banking like this http://dressthat.com/www-getipass-co...line-services/.
