Results 1 to 6 of 6
10-09-2008, 08:30 PM #1
Thread Treatment during Winterization
Does anyone use any kind of thread treatment on the manifold plugs, etc. when replacing after draining and flushing? TFS Paste or anything like that?
10-09-2008, 09:13 PM #2
I always use vasoline. The block plugs always come out easily at the end of the season.
07 LSV
If you can't fix it with a hammer you've got an electrical problem!
10-10-2008, 12:01 AM #3
10-10-2008, 11:35 PM #4Senior Member
- Oct 2007
- Panama City Florida
- 1,798
Teflon tape here too!
10-13-2008, 02:01 PM #5Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Teflon tape also. I leave the plugs out over winter. Last year rust built up in the block threads and had to clean them up with a tap before the plugs would start back.
10-13-2008, 02:48 PM #6Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
Teflon tape is good and as for cleaning threads if required a fitting brush for copper fittings works well. Just use gently and all should be good.
