Results 1 to 9 of 9
Thread: Fuel Filter
    Calgary Alta Canada
    Question Fuel Filter
    I'm nearing that dreaded time of the year when its time to put the boat away. Ya sure I can probably squeek acouple moreweeks with watching the weathercarefully,but other commitments say differently.Anyways its time to winterize and I for the life of me cannot find the part # for the fuel filter as i missed or didn;t need to do this last yr but figure why push my luck.We don't have high humidity problems up here,and so far no bad gas but i feel it should be changed.Does anyone know the part # preferably a GM part # so i can pick one up at an auto parts store vrs a so called marine version which i am lead to believe no real difference.I've gone through the manuals but no part #.I found the page with picture etcbut no info.Can anyone help me out here?
    I have an 07 Outback DD with 325 Assault motor.Also I assume its at the back near drip shaft etc and not to hard to get at and replace?
    Feb 2006
    Birmingham
    Here are a few part numbers. The filter shoud be easy to find. Just follow the fuel line from the fuel pump back towards the tank. Not exactly sure where it is on a DD.
    AC Delco GF482
    Hastings GF112
    WIX: 33482
    O.D. : 2 9/32 (57.9)
    Inlet : 3/8
    Outlet : 3/8
    Length : 5 1/4 (133.4)
    15 Mondo Surf Edition
    02 LSV - Traded In
    Calgary Alta Canada
    Smile
    I should have saved the box with the number but mine actually has 1/2 inlet/outlets. It was buried behind a panel at the very back of the boat in the ski locker area,as is the wakeplate pump/resevour which is behind another panel back there as well.Thanks for the help,i may go try to find that box,prt# for future info.
    Jul 2003
    The one with the 1/2 inch inlet and outlet should be Wix #33299. I just bought one today and had to look at about 5 different stores. I finally went to NAPA and they had it. Wix makes the filters for NAPA and the NAPA # is 3299. The one that was in the boat was a Carquest filter and I believe the number was 86299. I'm sure I'll remember it since I now need to go buy another one. I fumbled the new and it fell right into the water in the bilge and got submerged. Sometimes I wish the guys who engineer some of this stuff also had to work on it. I can barely wedge my meathooks between the 15 hoses and wire bundles, let alone remove the old filter and slide the new one in without dumbing a bunch of fuel into the bilge.
    Calgary Alta Canada
    Smile
    Those numbers are exactly what i ended up with except that mine is hidden behind a panel in the back ski locker and i had to worry about gas spillage on the carpet in there.
    Oct 2005
    Durham, NC
    Random question. When did Skier's Choice switch to the in-line style fuel filters? My 2001 Outback DD has the spin-on style. Just curious.
    Henderson, NV
    yea, napa has them as a stock item. 1/2 inlet and outlet. mine was also a carquest factory filter. napa fits like a glove, and it's about as tight as putting a glove on to get to them.
    I second the idea to make these things more user-servicable, but that's what keeps many going back to the dealers, and makes the sense of satisfaction that much greater once you do it yourself..
    and your 4-letter vocab up to date
    May 2007
    Naperville, IL
    Further Fuel Filter Question:
    I've got a '99 Outback DD that has a water separating filter (spin on) at the engine just below fuel pump. Is there an in-line filter somewhere else that I haven't been able to locate? Possibly back under the floor by the tank?
    Central NC
    Quote Originally Posted by Waynes345 View Post
    Probably not. Just follow the fuel line back to the tank.
    Let's ride
    07 FoilTech Hydrofoil
