Results 1 to 10 of 12
    Sep 2008
    Toronto
    Default Slalom Skiing- Wakeplate 03 Outback
    Hey Everyone.
    As of TODAY, I am the happy new owner of a 2003 Outback.
    Boat came with tower, ballast and wakeplate.
    I have been reading about wakeboarders wanting a BIGGER wake.
    We want a smaller wake.
    Can anyone give me the 60 second review of how I want to adjust the plate to get the smoothest smallest wake I can?
    15 year old son is skiing 30mph, The Bride is doing 34 and I am doing 36.
    All @ 15 off on a free ski.
    Thanks!
    Mike
    Johnston, Iowa
    Mike,
    I am a slalom fanatic also and have a 2003 outback. I don't have a wake plate but what I can tell you is that the Outback was built for slalom! Skiing behind I/O's as a kid I would say at the slower speeds you want the wake plate most of the way down to get the nose farther into the water. Once you get up to 32-36 mph I'd start it at a "neutral" setting and then play with it a bit. Once I get up to 34-36 mph the wake gets really small especially once you pass 22 off. Since your are free skiing - go out and shorten the rope to 28 off and head up to 34 mph and take soem wake crossings just to see what the boat is capable of...pure butter!
    Let me know if you have other questions and what your findings are.
    2003 Outback
    DFW, TX
    I don't have a wakeplate but I'd think you would want it all the way down to get the stern "up and out of the water" to decrease the wake.
    Oct 2007
    Panama City Florida
    Kidder is right, on our LS you have to put the plate all the way down. However, I thought the Outback was a pure ski boat?? It should have a small wake without the plate and I would guess it will get smaller if the plate is down.
    Calgary Alta Canada
    Smile
    I find with my outback DD at slow you can put the plate down a little to help but at 34,36 get the plate up and let the boat do its thing just as it would if it didn't have a plate. After reading posts from LS owners maybe the effect is different on there boats. But as stated outback dd are ski boats first and really don't need plates at all,plate is more for wakeboarding etc.
    Sled491 Guest
    Well guys you are mostly correct. Remember that an Outback without the Hydrualic wakeplate still has a wakeplate. On my 07 there is still 4 inch deep by about 20inch wide plate. This is there for a reason, and that is to help lift the back end a bit and flatten out the wake.
    So with that said, I would think that you would still need a small amount of the much larger hydualic plate to emulate a stock Outback slalom wake. For our friend that started the thread, the biggest need is for his son at 30mph.
    Calgary Alta Canada
    Smile
    I'm sorry i didn't realize you get some sort of plate as i ordered mine as an extra.I still find for skiing plate up works best especially at upper speeds.
    DFW, TX
    Quote Originally Posted by Mikey View Post
    Wouldn't that setting be like not having one?
    Calgary Alta Canada
    Smile
    In a word YES. I use my plate for wakeboarding and if i intentionally want the nose to ride high,ie rough water to keep some of the splash out.Outherwise for pure skiing I find i don;t need it.
    May 2008
    Cleveland, OH
    I have a 2008 Outback DD with the wake plate. I slalom ski at 35-36 mph at 15 off and don't run a course... appears to be the same scenario as Mike.Bates.
    Set the wake plate all the way down and leave it there! As others have said, it helps flatten out the wake for slalom skiing. I noticed right away that anything other than all the way down makes the lip of the wave a tad more harsh. And there is a slight bump at 22 off, so if you enjoy open water skiing at 15 off, it is nice and flat back there.
    Sure, the Outback DD is a certified slalom boat, but having the slight extra lift from the wake plate helps. It doesn't necessarily make the wake bigger or smaller, just changes the characteristic of the lip of the wake.
    2008 Outback
