Results 1 to 10 of 15
08-23-2008, 09:49 PM #1
My automatic bilge is no longer auto
I have noticed lately my bilge does not turn on unless I force it on with the toggle switch.
Any idea what could cause that?2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
08-23-2008, 10:34 PM #2Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
I would guess that the float inside the pump housing is stuck,not allowing it to come on automatically. Just unsnap housing at bottom of bilge area,i recall two tabs ,one either side of pump un click from base and check and probably clean . I have outback dd but i assume very similar if not the same.
08-23-2008, 10:42 PM #3
also,
there is a manual knob on the bilge pump..
turn it and see if it comes on.. that may free up anything stuck in the float.
BWBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
08-23-2008, 11:29 PM #4Senior Member
- Aug 2007
- Toronto, Ontario
- 187
Is my bilge pump automatic? I have always had to manually turn it on.
2007 Moomba Outback
99.999% Slalom, 0.001% Wakeboarding
08-24-2008, 12:06 AM #5Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
I have been known to just drop in a hose to wash the crud out. Sometimes saves pulling the pump
08-24-2008, 01:12 AM #6Sled491 Guest
Hey sometimes they just go bad, if I remember correctly Z's didn't run on auto from day one and had to be changed out.
08-24-2008, 09:29 AM #72008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
08-24-2008, 10:53 AM #8Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
yea, but when will you put it back together?
08-25-2008, 08:02 AM #9
I think I remember a post where somebody said the "auto" feature is on a separate fuse. Might want to trace that out.
08-25-2008, 08:50 AM #10
Ours was the opposite; it was always on. When we took it in for the 20 hour service they replaced the bilge and is well. I guess from construction that little pieces of carpet typically get stuck in the bilge causing it to malfunction.
2013 Outback V
