    Central Iowa
    Default Beginner Advice Needed!
    Due to a knee injury, I have been mainly driving the boat all year until last weekend. It was the first time I have wakeboarded since I was about 13-14 yrs. old. I am now 27. I have an 07' LSV and was wondering your best advice for beginners as far as speed, wake plate, ballast, etc. Any input is greatly appreciated.
    Last weekend the ballast was empty and speed was 14-18. Wake plate was all the way down (to keep boat flat) and it seemed like the middle of the wake was a little rough. I was using a 80' spectra line too.
    Do I need to shorten the line, move wakeplate up to get smoother wake, fill ballast or what?
    Also, board is an 07' O'brien Fluent 137cm. I am about 6' tall and weigh about 175-180. Do I need a little longer board. It sure felt as if my body was working way too hard while up on the board. I work out frequently due to profession and am in pretty good shape but still seemed to get way tired way quick. Any help??
    Thanks,
    Kip
    Ottawa, Ontario
    I fill all ballasts and keep my wakeplate down. If I bring the plate up the wake is not as crisp. I use a 70ft rope and its perfect.
    The slower you go the harder it will be on the arms. Slow speeds are great for learning surface tricks but you need speed to do jumps and ollies.
    Your board is totally fine. My CWB Pure 134 is good for riders up to 170lb.
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Dec 2006
    Tigard, Oregon
    Quote Originally Posted by strickland7 View Post
    Thanks,
    Kip
    Kip,
    When you say a little rough, I assume you mean it's got whitewash and not clean. I would suggest going a little faster, about 20 mph or so. And maybe shorten the line to about 70'. That should give you a clean wake at the point you are crossing it, and also be able to plane with less effort. I would also play with the wake plate (would start with it all the way up).
    I like to fill the front ballast in order to help keep the nose down instead of deploying the wakeplate so as not to kill the wake.
    Al
    Al
    May 2008
    Toronto, Ont
    strickland,
    we have the same boat (07 LSV) - assume you have the Gravity 3 ballast?
    On ours, we fill all three bags, 2 passengers up at the front, driver, and spotter. no wakeplate (as that flattens the wake) and i get a crisp, clean ramp even at 18.6 (using PP), and i think in the rope length is in the between 65-70.
    agree w/ cab though, the faster you go, the better it will get through the low 20's.
    Right now, my setup is as follows.
    Speed: 22 mph
    Ballast: Ski Locker filled (only have gravity I Ballast)
    Plate: All the way up.
    i think about 70 feet on the line as well..
    2006 Moomba Mobius LSV
    Stereo: Kenwood KMR-D562BT
    Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
    Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
