Results 1 to 3 of 3
Thread: Which boat cover?
08-11-2008, 02:30 PM #1Senior Member
- Aug 2007
- Toronto, Ontario
- 187
Which boat cover?
Hi. I have the standard snap down boat cover. Two of the snaps have broken on the bow cover.
Does anyone have the cover witht he draw string?
Some questions:
1) Can you use it instead of the snap down cover? Are they interchangable?
2) The draw string cover is better for trailering, right?
3) I seem to get some water leaking in when it rains. Is the draw sting cover better?
4) Is it easier to take on and off?
Thanks!2007 Moomba Outback
99.999% Slalom, 0.001% Wakeboarding
08-11-2008, 03:01 PM #2Senior Member
- Sep 2005
- Austin, Tejas
- 491
I have the drawstring cover and the snap on bow cover. The snap on is a pain to put on and take off. I find the drawstring very easy, especially with 2 people. I have not towed mine with the cover on, I'm not sure if it's safe or not, hopefully someone else will chime in and answer that question.
08-11-2008, 03:16 PM #3
1) Can you use it instead of the snap down cover? Are they interchangable? Yes
2) The draw string cover is better for trailering, right? No
3) I seem to get some water leaking in when it rains. Is the draw sting cover better? Yes
4) Is it easier to take on and off? Same amount of work2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
