Results 1 to 10 of 14
08-07-2008, 04:21 PM #1Senior Member
- Jun 2007
- 883
06 Moomba Mobius LSV - Transmission fluid
Hey guys, I have the details on fluids for the V-Drive and the Engine Oil... What does the transmission use?
Walter V-Drive (RV-26D-71V)
Pennzoil SAE 30 Motor Oil
Engine (Indmar Assault 325 5.7L EFI)
Engine Oil: Pennzoil Marine 15W40
Oil Filter: Pennzoil PZ3
Wakeplate
Regular ATF2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
08-07-2008, 05:55 PM #2
Somebody correct me if I'm wrong, but I believe that the V-drive is the transmission.
We are eternal, all this pain is an illusion.
08-07-2008, 05:58 PM #3Senior Member
- Jun 2007
- 883
well that's what I assumed.. But I found 3 dipsticks... 1 for the Engine, 1 for the V-Drive, and a red one that I was not sure what it was for... in the owners manual it says transmission.....
08-07-2008, 09:06 PM #4
08-07-2008, 09:33 PM #5
CSMSK,
The V-Drive is separate..
ATF Dexron III in my trans as well.
Trans fluid is easy to change cold with a vac pump.
V Drive oil needs to be warm or you'll never get it out.
I need to change my V Drive oil sometime soon...
I will need a little help on that to make sure I do it right. I know Jesse has posted several times about this.. i guess there is a drain on the bottom and something about some magnets? I guess I'll have to get into it to understand..Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
08-08-2008, 11:14 AM #6Senior Member
- Jun 2007
- 883
08-09-2008, 09:18 AM #7Senior Member
- Jun 2007
- 883
The only SAE30 around these parts is Castrol SAE30 HD (Heavy Duty)... Will this work for the V-Drive or is Heavy Duty wrong for this use?
From Castrol's Website
Castrol HD
A SUPERIOR OIL THAT PROVIDES MAXIMUM PROTECTION AGAINST THERMAL BREAKDOWN
Key Benefits
* Provides maximum wear protection in warm climates.
* Formulated to surpass the engine protection requirements for Ford ESE — M2C153 G and F, GM 6085M, Chrysler MS — 6395M.
* Exceeds API SM, SL & SJ performance for passenger cars and light trucks.
* Use HD 40 when ambient temperatures is above 60° F.
* Use HD 30 when ambient temperature is above 40° F.
Available Grades:
SAE 30
SAE 402006 Moomba Mobius LSV
08-09-2008, 09:56 AM #8
Spyder,
I can't say for sure, but I bought SAE30HD for mine.. just have not changed out yet..
BWBrad
2004 Outback sold
08-09-2008, 09:58 PM #9Senior Member
- Jun 2007
- 883
I just hear HD has more detergent then standard SAE30...
Any issues with that?2006 Moomba Mobius LSV
08-09-2008, 10:35 PM #10
I would check with the service guy at your dealer.
Al
