Results 1 to 3 of 3
Thread: Interior Lighting
08-03-2008, 10:47 PM #1
Interior Lighting
I bought some low wattage interior lighting that I was planning to put under the seats to illuminate boat at night. I want to use the spare accessory switch on my panel to control them, but I can't figure out all the wires and posts behind the switch. Which one should be the ground and which should be positive?
Thanks in advance.
08-04-2008, 08:00 AM #2
I hooked mine up to the courtsey light switch, but I used the accessory switch to power on my radio (I odered my boat without a radio) so I'll check which wires are which tonight, if you don't get a response sooner.
2013 Outback V
08-05-2008, 02:28 AM #3Junior Member
- Aug 2008
- 3
It is needed to check it to know which one is positve or nagative.The choice of fitting is according to the room , gets very difficult , one gets puzzled off as there are so many varieties in lights like the table lamps , spot lights , clamp lights , recessed / surface mounted lights , up lighters , halogens , incandescent bulb , pendants , fluorescent fixtures and lots of others.
