Results 1 to 8 of 8
07-31-2008, 01:22 AM #1Member
- Oct 2006
- Hong Kong
- 61
Belt squeek whining when accerlating from a stop!
I have a 2004 Moomba Mobius LSV with the standard Indmar V-drive 310hp engine, my engine belt squeek whining when accerlating from a stop!
Is it difficult to replace the belt myself? Seems like the water bump is in the way?
07-31-2008, 04:40 AM #2
I have an '04 OB. I haven't had to replace yet (277 hrs), but it can't be too hard. Have you tried to tighten it up?
07-31-2008, 06:00 AM #3Member
- Oct 2006
- Hong Kong
- 61
07-31-2008, 10:35 PM #4Senior Member
- Dec 2006
- tally, fl
- 283
I've got a dd and have tightened and replaced belt. had to take a stabalizing bracket off for water pump, but was no biggy, 15-20 min...havent had a look at v drives tho.
08-01-2008, 06:32 AM #5Member
- Oct 2006
- Hong Kong
- 61
I have just changed the belt it was so worn out! I simply unhook the water-pump water-line to install the new belt hope this is method is ok!
08-01-2008, 06:03 PM #6
you da man!!!!
.Learn all you can today. Tomorrow you may need to know it!
04-16-2009, 11:55 PM #7Member
- Oct 2006
- Hong Kong
- 61
04-17-2009, 09:43 AM #8
That's great. We have to assume that the reason you haven't been on here in a while is you've been out enjoying that Moomba.
