Results 1 to 10 of 11
Thread: stress cracks
    Sep 2003
    Default stress cracks
    My hull has cracks in the hull from the swim platform brackets. Due to stress. I want to fix it myself. Does any one have any input.
    Aug 2002
    Bismarck, NorthDakota
    Same thing happened to my boat. I would not recommend fixing it yourself. The glass shop I took mine too cut a 1 foot by 1 foot section out around the bracket and they glassed in a 1 foot by 1 foot piece of aluminum and finished it off with some matching gel-coat. Looks great and it has not come back (two seasons 250hours)
    Good luck
    Bruce Fuerstenberg
    Aug 2003
    Default gel coat cracks
    If you don't mind, what did they charge you for this? Also, what's the downside to leaving it alone?
    Aug 2002
    I caught it in time, very thankfully it was covered under warranty. It was around $2,500 but well worth it. If it is like mine was I think long term, eventually the brackets would have worked their way loose, maybe fall off and you would have a rather large hole in your boat (worst case).
    If you grabbed the platfrom and lifted a little you could see movement in the transome fiberglass where the swimplatform brackets were mounted. I would not take this lightly it is problem that needs to be fixed.
    Bruce Fuerstenberg
    Sep 2003
    is there a way to get behind the platform brackets with a plate for support?
    Aug 2002
    Yes, you have to take the trunk apart. I have a 2001 Mobius Pro. What boat are you talking about?
    Bruce Fuerstenberg
    Sep 2003
    We have a 2001 Kamberra walkthru. It looks like I have to raise the platform about 2 - 3 inches. Top lug screw just pierces the top of the stringer? I was going to have the the platform hanger enlarged with a backing plate to use some thru bolts. The platform could be too long or the hanger-bracket setup angled wrong. The walkthru looks tough to get a backing plate in there.
    Apr 2003
    Powhatan, VA
    If you haven't done it already, you might do a search on this board. This issue has come up before with the kamberras.
    Sep 2003
    Austin
    Just curious, shouldn't this be covered by the hull warranty?
    Sep 2003
    Wilmington, DE
    Is this a common problem on Moombas? Brian Raymond, has anything been done to prevent this on recent model boats?
  1. stress cracks...?
    By bobwells in forum Service & Repair
    Last Post: 11-24-2007, 11:01 AM
  2. Stress cracks around ski platform mounts
    By TN_Boarder in forum Service & Repair
    Last Post: 05-18-2007, 10:18 AM
  3. Stress cracks in hull
    By mattjj23 in forum Service & Repair
    Last Post: 07-10-2006, 01:07 PM
  4. Cracks in 04 XLV
    By Reno1843 in forum Service & Repair
    Last Post: 05-04-2006, 05:19 PM
  5. Continuing: Stress Crack - Tower Connection
    By burnsre in forum General Chat
    Last Post: 03-29-2006, 09:28 PM
