Results 1 to 10 of 14
07-22-2008, 06:45 AM #1Member
- Oct 2006
- Hong Kong
- 61
My fuel pump is rusted and leaking fuel!!! HELP!
I have a 2004 Moomba Mobius LSV with the standard v-drive 315hp engine, last week I found out my fuel pump has rusted through and slowly leaking gas while the engine is running luckily no damaged as occurred to the boat!
So now I need a new fuel pump, BUT no one has this part in stock over here in Hong Kong! Are there other marine grade parts that can be used to replaces this? Or if not where can i purchase this specific part online and Fedex this over! and whats the part number?
Here are some pictures of the rusted fuel pump!Last edited by etang789; 07-22-2008 at 06:52 AM.
07-22-2008, 09:45 AM #2Member
- Oct 2006
- Hong Kong
- 61
bump for help!
07-22-2008, 10:50 AM #3
I just got one online through SummitRacing.com, the PN was P4389 and it was half the price of anywhere else. incase it is not the same one just keyword Carter fuel pumps and all will come up.
Good luck
07-23-2008, 12:13 PM #4Member
- Oct 2006
- Hong Kong
- 61
07-23-2008, 12:47 PM #5
I sent an e-mail to our friends at Ski Dim to check this out for you. I asked them to include a quote and see if they could ship it too. I'll let you know what I find out.
07-23-2008, 03:08 PM #6Member
- Oct 2006
- Hong Kong
- 61
07-23-2008, 05:12 PM #7
When I took mine into the parts store they referenced it and it came up with the P4389. Also if you look on their web site all the specs are exactly like the one we have in their now. and it is designed for 12 volt marine use. Mine had the same PN as yours when I took it out.
07-23-2008, 10:51 PM #8Member
- Oct 2006
- Hong Kong
- 61
07-24-2008, 10:05 AM #9
Got a short response from skidim. They indicated that if the engine is carbuerated then the pump is their item # 0409. I went to their site and searched on that #. Here's the link to the page:
http://www.skidim.com/prodinfo.asp?number=RA080018
Not sure if this helps. Good luck!My Mom said I'm not allowed to get wet!
07-24-2008, 12:17 PM #10
Be careful on this one because it looks just like the one I got from the parts store and found out that the threads and fitting size for the inlets an outlets were different. They need to be 3/8.
