Results 1 to 10 of 11
Thread: Ballast pumps.
07-14-2008, 06:47 PM #1
Ballast pumps.
I think this question has been on here before. I need to know if it is all possible to change out the Ballast pumps on the boats. We went out this past weekend and waited for ever to fill the 750lb sack. I am not to concerned about the drain pump. I just want to pump water in faster.
TazzTazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
07-14-2008, 08:10 PM #2
Tazz, why not just do what I do? flip the switch on the way out to your favorite spot. They will be nice and plump by the time you get there. They fill up quick if you fill them as you move.
2007 LSV - All red
Wetsounds PRO 80's WS420 Eq
Acme 1433
07-14-2008, 08:30 PM #3
I did not think that youcan fill them on the move. I know that the front can not be fill while on the move. Will I get air in the bags? Also, this question is for my brother-in-law. He has 750lb bags throughout his Supra. It took forever to fill. And I do mean forever. By the Havasu was awesome.
07-14-2008, 10:43 PM #4
There was a post on WakeWorld regarding this with Supra's. One of the options was to put an additional pump on the line in to the solenoids... hard to describe but it is kind of a daisy chain... I think there are some higher GPH models available... but if i remember correctly, several said the 2nd pump inline helped much...
I just searched..here is the post from WW: http://www.wakeworld.com/MB/Discus/m...83/568342.htmlBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
07-15-2008, 12:54 AM #5
Tazz,
You can fill any or all three of the bags while on the move, and it seems to fill faster (probably because it helps force the water through the system). If you are getting air in the center sac, it's not because you are filling while on the move.
Let us know what you find out about going with a larger pump but I think that the sprinkler valves and hose sizes will probably be your limiting factor. You can only push so much water through that hose, and the valve/solenoids assemblies can only withstand so much pressure.
AlAl
07-15-2008, 07:34 AM #6
Cab--
Good to know. I will ask my dealer. They sell the Tsunami pump there.Tazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
07-15-2008, 08:32 AM #7Senior Member
- Jan 2008
- Lucas Ohio
- 107
when you guys say on the move do you mean idle or any plaining speed?
________
Kawasaki AR50Last edited by ajmoritz17; 01-22-2011 at 03:31 AM.
07-15-2008, 12:38 PM #8
Adam
I have done both, no problems.
I get air in my center bag but that is from my 20-25 mile tow to the ramp..
I generally have to burp it every few trips..Brad
2004 Outback sold
07-21-2008, 01:09 PM #9
07-21-2008, 01:46 PM #10Member
- Jul 2002
- Northern California (Seba
- 91
I have also filled my bags on the go and it wasn't a problem. The dealer also switched out my pump for the rear sack with a larger one.
I have a question on how to keep these pumps connected to the bags. They have this attachment like a waterbed filler but they will not attach to the bag. My rear one seems to stay but not the front. Have you guys had this problem and if you have how did you fix it?Lake Bound
2002 Moomba Outback LS
Indmar, Carb
