Results 1 to 10 of 17
07-08-2008, 04:06 PM #1Senior Member
- Jun 2008
- Novi, MI
- 108
How in the do you dock a Moomba? =(
This is my first inboard and I'm having a hell of a time docking it. When I idle it's going faster than I prefer to when docking...when I let off it turns on it's own. Backing up is even worse...it's like trying to back up a damn aquacycle.
I've had about five inboards and have learned to turn them on a dime and dock with the best of them...but this Mobius is giving me fits!
Does anybody have any pointers? HELP ME!!! =(Moomba Dad
Ausable Lake, MI
2004 Mobius LSV
07-08-2008, 04:12 PM #2
I was in the same boat as you. No pun intended. Pratice, practice, practice. I did and a year later I still get nervouse.
TazzTazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
07-08-2008, 04:36 PM #3Senior Member
- Jan 2005
- Alabaster, Alabama
- 143
Hey Dad,
45 degree angle to the dock on driver's side. Idle up, when you get a few feet from the dock put the boat in reverse. Use as needed. You should slow your forward motion and the back end should begin to drift to the right. It should slide in nice and easy.
Dave
07-08-2008, 04:48 PM #4
Iagree with you Dave. Just did not know to put it in words.
07-08-2008, 04:56 PM #5
use reverse to straighten out boat, find the easiest angle in then i pulse "in gear" "out of gear" repaet as needed. If you over shoot. Go around again try again patience and practice.
07-08-2008, 04:58 PM #6
I had a few close calls the first few weeks but I am starting to get a feel for it.
The more you do it the more you can predict how it moves.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
07-08-2008, 05:47 PM #7Member
- Jun 2007
- Fort Collins, Colorado
- 33
Definitely takes a lot of practice and experience. Like Dave said, I usually go at it at 45-90 deg. When I get around 5 feet away, I cut to the left which puts the driver side towards the dock. Then as I get to within a foot or so the boat should be close to parallel to the dock. Throw it in reverse to slow your forward progress more and suck the back end all the way over to the dock. If you can, have a helper jump off onto the dock to steady the boat. Be very wary of limbs between the boat and dock (saw a nasty hand/arm injury last year). Better to let your boat bounce off the dock than to lose a piece of yourself or someone else. All of this becomes much more difficult as the current or wind pick up, so be prepared.
07-08-2008, 08:09 PM #8
Great advice, entering at a 45 and keeping the dock on the drivers side has always worked the best for me. Best bet is to spend a lot of time in the no wake zone practicing. If you spend lots of time bumping the tranny in and out of forward and reverse you should be able to put that thing anywhere you want. By working the rudder in forward and banking on your "always backs to the right" you can go anywhere and even spin 360s if you are careful. Biggest advice is always come in slow.
07-08-2008, 08:31 PM #9Senior Member
- Jun 2008
- Novi, MI
- 108
I was hoping that you all wouldn't tell me I need to come in from the starboard side. I dock with the dock on the port side...at least for now. Looks like I might have to switch all of my tie down, hooks and bumpers between the Bennington and the Moomba so that I can have the dock on the starboard side.
Thanks for the info though. It does always rotate counterclockwise when I hit reverse though.
Moomba DadMoomba Dad
Ausable Lake, MI
2004 Mobius LSV
07-08-2008, 08:40 PM #102008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
