Results 1 to 8 of 8
Thread: Drivers seat Play OBV 07
07-01-2008, 07:04 AM #1
is it normal to have a little play in the drivers seat side to side or should it be rock solid. it slides front to back perfect but when hanging out in the waves i can feel side to side play.
Any thoughts?
Can't wait to see the DIY swivel seat option.....A Day at the Lake...Priceless
07-01-2008, 07:49 AM #2
Mine is rock solid.
2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
07-01-2008, 02:35 PM #3
07-01-2008, 08:19 PM #4Reese350 Guest
I double checked mine (06 LSV) while I was out today and it didn't have any play in it. Something must be loose.
07-01-2008, 10:41 PM #5
thx i will check them out thursday eve, long weekend looks nice, hopefully no wind...
07-05-2008, 08:01 AM #6
What's the best way to remove theseat to get to the bolts???
They are loose and need to be tightenedA Day at the Lake...Priceless
07-07-2008, 07:32 AM #7
bump,
need help getting seat off to get to loose bolts. any thoughts.
thx in advanceA Day at the Lake...Priceless
07-07-2008, 02:41 PM #8
jm,
What boat do you have and what does the seat look like? I have a 2006 LSV and it has the tilt up bolster. On this seat, I tilt up the bolster and unsnap the 4 snaps on the front of the seat and pull back the "cover". This exposes the two front bolts/nuts. To get to the rear bolts/nuts, remove the 4 philips head screws that are about in the middle of the seat. You have to have the bolster tilted up to see them. After removing the 4 screws, push the seat bolster into the down position then lift up and remove the fixed part of the seat cushion (the 4 screws attaches the fixed (rear) seat cushion to the seat shell). That exposes the rear bolts/nuts. If you have a different seat, this may not apply at all.
Hope that helps.
AlAl
