Results 1 to 10 of 10
    May 2008
    NW Montana
    Default Boat Lifts/inboard friendly?
    I just bought a Hewitt cantilever lift with the "inboard bunk kit". This kit is supposed to allow for an inboard prop to clear the top rear rail. After putting it together and adjusting the bunks' spacing, I'm still about two to three inches from clearing the prop(the fins seem to clear by 3 inches). Anyone else have a close fit and what did you do to remedy it?
    Kurt
    2008 LS
    How far apart are you bunks?
    Oct 2004
    Marietta, GA
    Don't think I have the same kind of lift, but the spacing of the rear bunks may be a good place to start. Secondly if that does'nt work I'd be on the horn to the dealer. My 2 cents.
    Aqua
    2005 Moomba 23 XLV
    340 HP, Clarion 5 HU, 2 Clarion wired digital remotes, 2 Wetsounds 485's, 6 Wetsounds XS 650's, 1 JL 12w6 Sub, 1 Wetsound WS420, 2 JL 300/2amps, 1 Wetsounds Sync 4 amp, 1 JL 500/1 amp. Teak swim platform, Perfect pass. Flip up Bow Light, Chrome tower Nav Light, Chrome thru hulls, Black Bimini, 2 750 Flyhigh bags, 1100 center Flyhigh bag, Acme 1235 14.25 x 14.5 prop, Dual battery system. Evolution Cover. Chrome Blower Vent Covers.
    Pensacola, FL
    I have the Hewitt Cantilever lift. I put it together 4-5 years ago, so the details are pretty foggy. I didn't buy the "inboard" kit. I bought to pieces of aluminum square and mounted 2"x4"s on them for bunks. I gave me the clearance that I need and was a little cheaper (at that time).
    My MC is pictured and I measured the spacing of the bunks on the trailer to set it up. I have not adjusted it for the Outback yet.
    I hope this helps.
    May 2008
    NW Montana
    Thanks for the input. I called Hewitt this morning. The tech rep said that the inboard bunk kit is made to clear fins and and drive shaft, but not prop. He said that the boat should be well balanced on the lift (esp. DD). A bow stop was highly suggested however. I figure that side guides should be placed as well if others are going to dock the boat.
    Kurt
    May 2008
    NW Montana
    Sorry, bunks are about 4 feet apart. Boat looks well seated in the bunks at this spacing
    Kurt
    Reese350 Guest
    I have a cantilever lift too but it's a different brand (Great Lakes Lifts). My prop does not clear but like your rep suggested, it sits nicely on the lift without pulling it that far up. We've just had to get used to positioning it so we don't ding the prop or put pressure on the shaft. Once you get used to it, it's not so hard to do.
    Enjoy the new lift!
    Scott
    Smile
    Kurtl,
    i had these questions when i put my lift(non cant, vert lift) together. The prop should never goes past the stern cross bar. i picked a spot on the boat after i walked it in the 1st time to pull the boat forward to. key don't lower the bunks to far or the boat may pull too far forward and damage the shaft, thus the dealer recommended bow stop.
    Good luck
    https://forum.moomba.com/picture.php...&pictureid=113
    the rear cross bar is forward of (square box) motor. I can get you better pics this weekend if you want.
    BTW this is a Great lakes hoist, my buddy has a hewitt Cantalever, but has an I/O in it at my other dock.
    Jul 2006
    Fargo ND
    My bunks are positioned to clear the tracking fins. My boat lift sits in the middle of a "Y" so it is impossible for me to drive my boat too far forward. I would highly suggest getting a bow stop! Not because you would drive your boat too far forward but it only takes one well meaning guest to cause a lot of dammage.
    May 2008
    NW Montana
    I just placed the order for the bow stop. Thanks for all the info.
    Kurt
