Results 11 to 20 of 21
Thread: Fat Sacks and Prop Size
06-29-2008, 07:17 PM #11
dt,
If you are running fully loaded all the time, you will get better mpg with the correct prop (i.e., the wakeboard prop) because your engine is operating more efficiently (not working as hard). But at light loads, you would burn more fuel because a prop with more pitch will do the same job at fewer rpms.
That is my understanding anyway.
AlAl
06-29-2008, 07:20 PM #12
Cab--
That is exactly what I have. I need to get the number from aqua. I really need to talk to the prop guy before I shell out another $500.00 bucks. Thanks for your help. I found the member that posted about the custom tanks. In his post, he said that the cost was $125.00 per tank. I had asked for the guys information and some pictures.Tazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
06-29-2008, 07:22 PM #13Tazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
06-29-2008, 07:23 PM #14
Tazz,
No worries, and good luck. I typically go out with just a few people, or another couple with a couple small kids so I have not run into any performance issues yet. Once I do, I will probably have to get another prop as well.
AlAl
06-29-2008, 07:25 PM #15
06-29-2008, 07:27 PM #16
06-29-2008, 11:38 PM #17
New prop for my 05 lsv
Well I needed to get another prop for the boat and this altitude. I inquired to OJ and Acme and recieved responses from both companies. Acme recommended the 537 and I purchased it . I replaced the oem oj 13.7 x 17.5 which I will get repaired and keep for lower elevation when I travel. What a difference the Acme made. Silky smooth , outstanding hole shot with 2 350LB sacks in the back , 3 people on board and mile high elevation . My buddy runs the same prop on his Tige z boat and likes it. I guess it depends on where you run your boat at and how loaded it is. I also for got to state that I have an indmar assalt 325hp engine. Jim.
06-30-2008, 01:35 AM #18Senior Member
- Feb 2008
- Houston, TX
- 119
I just upgraded my two rear sacks from #400 to #750. Using one #750 in the rear provides a great surf wake. After I got the new bags, we messed around with the #400s placing them on the side seat and in the bow.
When we switched to wakeboarding, I simply filled the rear starboard #750 and off we went. Well, almost. My boat has a good holeshot, but even with only two people in the boat, #2700 of ballast makes the boat take forever to get on plane.
I decided that #750 is great for surfing, but for wakeboarding I need to back off to #600 or so. This allows the boat to quickly plane out without changing the prop. Altitude is something you can't control, but if you have more people, make sure you reduce your ballast and space them out so that the rear isn't over-loaded.-ryan
'10 Wakesetter LSV
06-30-2008, 08:34 PM #19
Just talked with the guys at www.borditup.com. Very nice people. I will be ordering my new prop tonight.
06-30-2008, 08:38 PM #20
Which one are you getting?
Al
