Thread: setting up
    Default setting up
    Just tried setting my outback v for wake surfing, and was having trouble seting it up, i have the factory ballast in the center and rears and had 5 bodies in the boat,
    wondering how to set it up.
    or if its possible with this boat.
    Ottawa, Ontario
    I would love to know also!
    I have the stock Gravity III ballast and was curious how much weight each bag is. I was told 400lb each (1200lb total). If that is the case then I would need at least one 750lb bag on the surf side correct?
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Nov 2003
    Land O Lakes, Florida
    my set up-2003 lsv--same hull as yours.
    i have a 800lb bag in rear surf side locker--it does not fill to 800lb but i do fill it all the way--it completely fills it up to the lid-had to cut foam pool noodles to fit around the opening and on the hatch strutt bracket so it protects the bag, gravity one bag filled, put a 500lb bag in the bow walk thru, a 500lb bag across the rear seat. with this set up my rub rail is about 3 inches above the water---look for my pictures in the post"what is your setup". as for speed-my speedo reads 15mph-i know its off, i can tell when surfing we are at the right speed cause the boat exhaust sound frees up and the swimm platform is out of the water.
    stacy
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Mar 2008
    Vancouver WA
    Only fill the bow sack and the rear sac on the side you plan to surf on. If you want to get an even more surfable wave take the sack your not using and put it on the seat on the surf side as well. Then get all your passengers to get to the surf side. You might put 1 or 2 in the bow. but the outback V doesn't need too much up front. That is the set-up.
    Works every time.
    Good luck!
