Results 1 to 10 of 20
    colorado
    Default aux input on kenwood stereo
    we were sitting the the boat tonight talking about our upcoming trip to lake powell. My daughter had her ipod and wanted to hear her music. we plugged into the aux input and pressed the source button, but the unit would cycle between tuner, CD, and standby.
    i thought that we only needed to cycle through the sources, should i do something else? is my input bad?
    we also tried an mp3 player and 2 separate cords. both worked in other units.
    Lake Allatoona, GA
    I can't remember exactly how to do it as I dont have the book with me, but you have to get into the menu and turn on the aux input. Its very simple to do, it will tell you how to do it in the book. Sorry I cannot give you the exact steps. Someone may chime in with the steps, I'll be at the boat next week, if you still need the steps then I will look them up and post the steps for you.
    Mark Miller
    2010 Moomba LSV
    2008 Moomba LSV - sold
    Ottawa, Ontario
    I was under the impression you need to buy a kenwood adapter to plug into the back of the deck to connect an ipod.
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Lake Allatoona, GA
    Quote Originally Posted by deafgoose View Post
    Thats true if you want to be able to control the ipod with the head unit or your remotes. But if you just want to use it to play music, you can use a 3.5mm to 3.5mm cord to connect the ipod to the input on the front of the head unit.
    Mark Miller
    2010 Moomba LSV
    colorado
    i may not have been reading the book enough, i thought it said to simply scroll through the source button until the AUX comes on. i did not understand that i had to turn on the AUX separate.
    will try some more tonight.
    thanks
    Feb 2008
    Traverse City, MI
    Quote Originally Posted by yearround View Post
    thanks
    You will only have to turn the Aux Input on once. Once you do it it will be come one of the "SRC" options.
    colorado
    we poked around for a while last night, finally figured it out. now we can listen. not at all along the lines of my illogical thinking.
    thanks all for the help
    Feb 2008
    Houston, TX
    See my (updated) post on installing a newer Kenwood that includes an iPod control. I mounted the USB plug for the iPod (or any USB device) in the glove box with the stereo, so you can play the iPod with the box closed and no external wires and still pause/play and skip from the driver's side.
    https://forum.moomba.com/showthread.php?t=5109
    -ryan
    '10 Wakesetter LSV
    Aug 2006
    Salt Lake City
    Yearround
    What did you have to do to the unit? Mine started that this weekend..
    I was running ipod through the sirius unit (with 13 pin din connector) and after that started, i unplugged the sirius unit(dont use) and it worked briefly and then started again.. i had to burn a cd!
    Thanks in advance
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Apr 2010
    Colorado
    Mine did the same thing it used to work till people started messing with my radio now when I hit src it goes radio tuner standby no aux hook up must be something easily switched I guess If you could post steps that would be great
    thanks
    Bruno
    ~Prove it~
    2008 Moomba Outback V
    Upgrades SO FAR more to come for the summer!!!!
    new decals, tinted winshield, new trailer tires.....
