Results 1 to 6 of 6
Thread: Winterizing
    Aug 2003
    Default Winterizing
    I have no owners manual and my dealer "can't" get one for me. What do I need to do to properly winterize my boat? Thanks!
    Jul 2002
    London Ontario Canada
    Default winterizing
    i have a 99 outback ls w ballast tanks.....I put gas stabilizer in full tank of gasfirst and run thru engine (very important ), fog engine, change oil n filter, remove impeller, drain block(two draincocks on lower block), tranny cooler(disconnect lower cooler hose),exhaust manifold ( quick disconect), water pump (disconnect hose to pump located just above impellar), fill block thru stopcock with -50 plumbing antifreeze (insurance and lubrication), disconnect battery and store in basement not on concrete and charge in mid january, pour about 1 cup plumbing antifreeze in ballast exhaust so pumps dont crack(experience), ......has worked well last 3 winters in northern ontario with no problems at all in spring..... anyone has any other add ons ,i think i got it all save cover n wax
    doug
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Jul 2003
    Carson City, NV
    Default Owners Manual
    Go to indmar.com. They have an online manual. It has the information there.
    However, this is just the winterizing info for your engine. Remember, there are things that should be done for your boat as well. Check your owner's manual for a complete list of recommended checks.
    Aug 2003
    Default Winterizing - No Boat manual
    Got the info off Indmar site- thanks - but since I have no boat-owners manual, what type of non-engine maintinence needs to be done?
    Jul 2003
    Carson City, NV
    The primary thing is to ensure that there is absolutely no water in the boat (ballast systems included of course). Usually, just a good cleaning and making sure the thing is dried out well, covered and protected from the elements.
    I have seen some other detailed instructions that I found once on the Malibu forum. Good Luck.
    Jan 2003
    Clermont, Florida
    Here's a link to a really good article on how to winterize your boat, from the Mastercraft people.
    http://www.aquaskier.com/articles/bo...terization.htm
    Brian
  1. DE-WINTERIZING?
    By LSV04 in forum Service & Repair
    Last Post: 05-06-2012, 09:44 PM
  2. Winterizing
    By Father of 5 in forum Service & Repair
    Last Post: 10-11-2010, 05:21 PM
  3. winterizing
    Last Post: 11-18-2007, 12:42 AM
  4. Winterizing
    By mattjj23 in forum General Chat
    Last Post: 10-09-2006, 11:32 AM
  5. Winterizing
    By in forum Service & Repair
    Last Post: 08-17-2005, 05:38 PM
