    May 2002
    chicago
    Default freezing temp./engine
    Im concerned.
    I was planning on winterizing my boat Oct. 4th, a week from Saturday.
    The boat sits on a lift, out of the water, 8 hours from me.
    Problem is, i noticed that the weather is going to dip into freezing temperatures (30 degress one night and 29 the other) twice before i get there.
    How dangerous is this for my engine?....Is this reason to panic?
    Guest
    Can you get anyone to throw a light bulb in the engine compartment just to be on the safe side?
    Jul 2002
    Mechanicsville, va
    I was told by my mechanic that you have to be below freezing for at least 24 hours straight for any damage to occur. As long as the temperature goes higher during the day you should be alright. Of course, your mileage may vary........
    Mar 2003
    s.e. washington state
    Default Based on Many Elements
    I have had no problems at those temperatures mainly because of the hull and covering the engine will probably not see much if any freezing temperatures. Even if it did, the water in the engine would have to completely freeze to expand enough to cause damage. You would be more vulnerable in areas more open or surrounded by less mass such as your water heater and shower which at those temps still wouldn't be a problem. I had that same experience here in Washington State last year when an unexpected cold front came through when I was on travel. How times change..90's all this week and mid 90's over the weekend. So glad everyone put their boats away for the winter. Can anyone say...glass? Gives us an excuse to go to the beach and watch the Sea Chickens.. I mean Seahawks play. I wouldn't lose sleep over the temperature thing as long as it doesn't get much colder than that.
    1998 Mobius
    310 HP PCM
    May 2002
    chicago
    Thanks for the replys. I appreciate the thoughts.
    I bet yur "Chicken Hawks" would beat up on my Chicago Bears! We have the Cubs right now---at least for a little while.
  1. Water Temp
    By pullmyfingers in forum Skiing & Slalom
    Last Post: 04-09-2008, 10:39 AM
  2. Freezing Temps Tonights!!!!
    By jdsharpe57 in forum Service & Repair
    Last Post: 03-06-2008, 03:35 PM
  3. Operating Temp
    By YellowMoomba0 in forum Service & Repair
    Last Post: 06-29-2006, 02:00 PM
  4. Water freezing in my boat??
    By Nboard10 in forum General Chat
    Last Post: 02-08-2006, 10:47 AM
  5. engine temp
    By BLKOUTLS in forum Service & Repair
    Last Post: 07-25-2003, 09:36 PM
