Results 1 to 3 of 3
Thread: Electrical Question???
05-27-2008, 09:34 AM #1Junior Member
- May 2008
- 8
2005 Outback. The wire came off of my battery gauge. While driving through a canal I blindly reached under the dash to slide it on the post and put in on the post that already had a wire on it. Everything on the boat shutdown. I then went to the battery compartment and reset the switch mounted above the battery. All accessories work but the ignition doesn't even make a noise when the key is turned???? Any ideas of what to do next??
05-27-2008, 10:13 PM #2
Check to see if there is a circuit breaker for the ignition.
05-28-2008, 08:14 AM #3Junior Member
- May 2008
- 8
Thanks! I found the ignition switch!!
