Results 1 to 7 of 7
    Oct 2002
    Ottawa, Canada
    Default Iron Stains on Gelcoat
    My hull has apprently been sprayed on (nightly) by a sprinkler whoch has resulted in rust-coloured staining of the white gelcoat...
    ...how do I get it off?????
    Mar 2003
    s.e. washington state
    Default Check Out the Professional Car Washes
    I've had problems with sprinkler systems and mineral deposits from an automobile standpoint. I've used a local professional car wash which uses a vinegar solution and if you know what your doing you can do it yourself. The rust color may be from iron deposits and perhaps your local company may know the solution (pardon the pun). The next step is to redirect the sprinkler.
    1998 Mobius
    310 HP PCM
    Jan 2003
    Clermont, Florida
    White vinegar is good for removing waterspots....I've used it on painted surfaces and windows. If that doesn't work, I'll bet that a mild polishing compound would remove the stain. 3M makes a good hand polish called Finesse, it's made for hulls. You can find it in the marine section at Walmarts. Let us know how you make out.
    Brian
    Jun 2003
    New Orleans, LA
    I have used this stuff called ZAP on my boat...and it takes care of the stains and other spots on the hull. try is in a hidden area first to test it. good luck.
    Patrick S.
    Oct 2003
    Northern Kentucky
    I have always used the fiberglas version of a product called Zing. Works great on waterline marks as well.
    Oct 2003
    Northern Kentucky
    Oct 2002
    Ottawa, Canada
    Results:
    I tried the Vinergar ---- did not work.
    I tried a soft auto finish polish ---- did not work.
    I tried Super Iron Out ---- did not work.
    I tried Maguire's fiberglass restorer ----- WORKED!!!!
  1. Help w/gelcoat stains.
    By lowdrag in forum Service & Repair
    Last Post: 10-21-2007, 09:47 AM
  2. Lake stains
    By Fat G in forum Service & Repair
    Last Post: 07-25-2007, 12:16 AM
  3. help with stains
    By ben624 in forum General Chat
    Last Post: 09-30-2004, 08:09 AM
  4. Gas Stains On Fiberglass
    By pss3757 in forum Boat Owners
    Last Post: 07-29-2004, 02:08 PM
  5. Water Stains
    By SMUMATTMAN in forum General Chat
    Last Post: 11-25-2003, 06:12 PM
