Results 1 to 7 of 7
Thread: Question for XLV owners
05-23-2008, 11:23 AM #1
How in the "H" do you get all the water to drain from your boats? I pulled the plug, put an 8" block under the trailer jack, then jacked the trailer up all the way. I still had water in the front and in the back under the motor.................
05-23-2008, 03:36 PM #2Junior Member
- May 2008
- Losantville IN
- 4
A wet shop Vacuum would work but I use a big sponge and bucket.
05-23-2008, 04:31 PM #3Member
- May 2008
- Jacksonville FL
- 42
I sometimes take the plug out and let it sit on the boat ramp for a bit, and floor my truck from a stop. That helps some, but I doubt you can get all the water out. Unless it is salt water, I don't think it matters if a little water is in it.
05-23-2008, 05:58 PM #4Member
- Jan 2007
- Sparks, Nv.
- 56
Problem is water gets trapped under the center bag, so just take it out every once in a while
05-24-2008, 02:31 AM #5Senior Member
- Feb 2007
- Orange County, CA
- 213
Seriously, under the center bag is the worst...I bought a hand pump from West Marine
http://www.westmarine.com/webapp/wcs...5&classNum=168
But still unless you suck the water out every time you end up with "slime" under the bag...such a messContrary to popular belief, a boat does not run on "Thank Yous"
05-24-2008, 10:03 AM #6
I just use the shop vac.
07 Mobius LS--Razorback Red
05-27-2008, 09:18 PM #7
Hmmm…we haven’t noticed this problem…yet?
Texas is a Great Country!
2008 XLV 1100# sacks X3! Whooya!
