Thread: 2005 mobius LS
05-19-2008, 04:53 PM #1Junior Member
- May 2008
- dallas
- 4
2005 mobius LS fuel issue
Filled up at the gas dock the other day and started having a problem accelerating out of the hole. If i get on the throttle hard (pulling a boarder out of the water) the boat hesitates 2 or 3 times before coming up to speed. does this sound like water in the fuel? or a bad fuel filter. I can not find any any details on replacement filters. thanks, any info appreciated.
05-19-2008, 05:08 PM #2
I had the same issue last year. Changed the filter and problem was solved.
07 Mobius LS--Razorback Red
05-21-2008, 01:58 PM #3Junior Member
- May 2008
- dallas
- 4
05-21-2008, 02:51 PM #4
Not sure where it is on your LS, but if you follow the fuel line down into the hull, you will eventually find an inline 3/8" inlet filter usually against the bottom of the hull.
Here is the part number for the one I use: Hastings GF11215 Mondo Surf Edition
02 LSV - Traded In
05-21-2008, 07:35 PM #5
On my 2003 LS the fuel filter was mounted on the inside of the stringer,starboard side ,right under the blower motor.(hard to see).My local auto parts cross referenced it to a WIX #33482
jy
