Results 1 to 10 of 28
Thread: which Perko?
05-15-2008, 01:06 AM #1
which Perko?
I'm discovering that there are a few different Perko switches. Which one is the way to go for two amps and the usual accessories?
05-15-2008, 12:42 PM #2
I would go with the 1, 2, All, Off version
05-15-2008, 04:36 PM #3Senior Member
- Nov 2007
- 190
I went with an automatic relay. No need to fiddle with a switch, or worry about my kids turning it off when the boat is running. Plus it is more efficient than an isolator.
Just something to consider.
05-15-2008, 06:40 PM #4
I'm in the no perko camp! I had an isolator on the previous boat and no intervention required. They installed a perko on the LSV and i can't stand it, always forgetting to switch between batts. I'm removing it and installing a regular so i don't have to mess with it!
05-15-2008, 11:57 PM #5
so a regular isolator instead of a perko?
05-16-2008, 12:31 AM #6Senior Member
- Nov 2007
- 190
I'd look into relays vs isolators. This is a decent read. There is a ton of other info out there.
05-16-2008, 02:44 AM #7
I think if you donīt install a switch, you canīt disconnect the batteries...this doesnīt seem too safe.
I installed what SC recommended, check it please:
http://www.bepmarine.com/Single-Engi...-180-1460.html
And leave it always in " 1 " position when running, you can switch to " 0 " when boat is not on the water, I think is safer, least I do this.Last edited by moomba_armada; 05-16-2008 at 02:47 AM.
05-16-2008, 09:32 AM #8
There are other ways to disconnet the batts, i have a 50amp breaker as well. Push the button on the breaker and the batts are disconnected, flip the lever and they're connected. An iso/reg will charge both when running and disconnet the second batt while parked, that way it never drains the starting battery. A regulator has no amp/volt loss across the batts either. I ran the last boat two years that way without issues and i had a 1200 watt peak system in it. Disclaimer; just my 2 cents!
05-16-2008, 09:36 AM #9
Also remember that mfgrs recommendations will always err on the side of caution. They ALL recommend a battery disconnect for dual batts. The only exception i know of is Tigé which actually uses an iso/reg type system on their factory dual batt installs.
05-16-2008, 10:06 AM #10Senior Member
- Nov 2007
- 190
Yep, isolators and relays do disconnect the batteries when the ignition is off. It's just automatic so you don't have to mess with switches. The wiring is a bit more complex, but no big deal.
