Results 1 to 8 of 8
Thread: water anyone
    May 2008
    Houston, TX
    Default water anyone
    Has anyone ever had water get into their v-drive (meant transmission)? Just wondering where i should start looking for where it entered, knowing that I'm going to have to now flush it out somehow.
    Apr 2007
    Las Vegas, Nevada
    You should have an automatic bildge pump in the boat. Or plug the plug at the a$% end of the boat. When and how did you notice this water?
    Feb 2006
    Birmingham
    Are you saying there is water in the actual V-Drive itself or water is in the bottom of the hull? If there is water in the V-drive itself, how much water did you notice. I will check the exploded schematic when I get home today if you are refering to water in the V-drive itself. What year is the boat and waht model?
    15 Mondo Surf Edition
    02 LSV - Traded In
    May 2008
    Houston, TX
    Sorry, it's a Gravity XLV 2006
    I notice the transmission fluid was milky this past weekend. I did notice one of the water fittings for what i'm guessing is the front (middle) "Gravity Ballast System" was not screwed on tight and seemed to be squirting on top of the dip stick for the trans fluid. The color was pretty creamy which doesn't sound to good.
    Oh and thanks for the help
    May 2008
    Houston, TX
    Just in case anyone sees this post again. The problem was water in the transmission which was caused by a leak in the transmission's oil cooler. Just replaced it with a new one from skidim.com and haven't had problems since.
    I hope you replaced all the fluid, ran it, then did it again to be sure.
    May 2008
    Houston, TX
    Definitely. It had taken 4 flushes for the transmission to operate with out signs of water. Hooked up a hose adapter to the V-Drives water intake and ran the engine each time. After wards tested out on the water around the lake checking constantly. Still clear of water.
    I'm very glad to hear it. Also glad you're vigilant. Lots of guys would have been in for an expensive service appointment.
