Results 1 to 3 of 3
Thread: Bimini Help
05-12-2008, 06:58 AM #1Senior Member
- Jan 2008
- Lucas Ohio
- 107
Bimini Help
I know its a pain in the a$$ but can anyone send me pics of there lsv with the bimini down? I cant get mine to clip in so im thinking something has got to be wrong with the way its set up. the straps are all the way out and I have pulled and pulled and im just a few inches short.
________
hempLast edited by ajmoritz17; 01-22-2011 at 03:28 AM.
05-12-2008, 01:26 PM #2
AJ,
I am gonna make an assumption as I had the same problem. When you put the bimini up, you have to shorten the arms that hold it up (push in the push button locks) and click it down one level.
CAB(Al) had a suggestion of getting longer straps at marine store and you can have the top up with more head room if you replace the front 2 straps. I did that over the winter.
It was designed to be lowered from it's resting position... Hope this helps..Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
05-12-2008, 01:49 PM #3Senior Member
- Jan 2008
- Lucas Ohio
- 107
wow sounds like the longer straps will be the way to go because if i remember right there wont be much head room at all
Thanks for your help
________
ultimate fighterLast edited by ajmoritz17; 01-22-2011 at 03:29 AM.
