Results 1 to 10 of 12
Thread: leaving boat in water?
04-24-2008, 09:34 AM #1Senior Member
- Jan 2008
- Lucas Ohio
- 107
Does anyone leave there boat in the water? I live like 5 minutes away from where i wakeboard most of the time but my dad bought me a dock space right next to his boat. It would be nice to not have to deal with trailoring boat and just head straight to lake from work. but as it is now i pull boat out of water and wipe it down. I would be pulling it out of water at least once every 2 weeks probably once a week to gas and clean.thoughts?????
________
TR200Last edited by ajmoritz17; 01-22-2011 at 03:27 AM.
04-24-2008, 09:43 AM #2Senior Member
- Mar 2005
- t-town
- 718
leaving the boat "in" the water for long periods can result in blistering on the hull. not covered under your warranty.
don't do it, unless you have a lift.
04-24-2008, 10:18 AM #3
boats are made to be in water arent they??? what if you go on a weeks vacation somewhere, do you pull it out everyday to wash it and clean it?? I leave mine in for months at a time, I scrub the hull while its in the water at a sandbar every now and then. No blisters. No Problems. And much easier access everytime I want to go riding after work when those daylight hours are precious. Spend your time using your boat rather than worrying about it all the time, youll enjoy it more I guarantee it
04-24-2008, 11:32 AM #4
I also plan on keeping mine in a slip at a small marina. The only thing to be careful on is that you tie it up properly, you don't want it bouncing off the docs when other boats pass by.
04-24-2008, 01:09 PM #5
aj,
I do exactly what you are talking about. I leave my boat in my lake access community slip for a week or two at a time. Usually pull it out for gas and clean the water lines and use a car crawler to thoroughly clean the bottom. If it happens that it stays in two weeks or more, I use starbrite hull cleaner to dissolve the water line then clean and protect with Ice synthetic spray detailer by Turtle Wax. This stuff removes all water spots in a 20 minute wipedown.
I used to keep in on the trailer between uses, but what I found was that I didn't use it half as much due to the extra time to hookup, launch park, get trailer and store. It is worth the cleaning effort once every two weeks to have it sitting in the slip ready to go for nice days and weekends.-Jay
2008 Supra 21V
04-24-2008, 01:13 PM #6Senior Member
- Mar 2006
- Chapin, SC
- 159
I leave mine at our neighborhood slips. Pull it out every week to gas and clean. Two weeks is the longest it will sit. I use star-brite hull cleaner and a soft extenable brush. I put two capfulls of hull cleaner in a bucket and add about 2 to 3 cups of water, then scrub the bottom and rinse well. The trick is to do this within 20 minutes of pulling out of the water. Scrub about 25% of the hull and rinse, then move on. I have it down to about 15 minutes total and it makes the hull look brand new again. I have done it this way for years and never had a problem.
I mess with Texas
04-24-2008, 01:17 PM #7Senior Member
- Mar 2006
- Chapin, SC
- 159
I mess with Texas
04-24-2008, 01:43 PM #8Senior Member
- Jun 2007
- 883
on't know whats going to happen with the moomba yet, but our old I/O would spend the entire season (5 or 6 months) in the water up at the resort where our trailer is in a small wharf, sure it looked ugly at the end of the year, but it all came off no problem with a good year end cleaning.
2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
04-24-2008, 08:16 PM #9
Things that concern me are related to the shaft seal and bilge/battery failure.
My concern about prolonged time in the water is if the bilge pump fails or the battery fails. A sudden influx of water or leak through the shaft seal could sink you.
Our boat is on lake at a dock - on a lift....If you believe something to be true, it will be - in it's consequences.
04-24-2008, 08:27 PM #10
Hey Yellow,
What’s this I mess with Texas stuff?Texas is a Great Country!
2008 XLV 1100# sacks X3! Whooya!
2006 Active Water Sports Boat Buyers Reunoin
By gerryaws in forum Boat OwnersReplies: 0Last Post: 06-14-2006, 12:56 PM -
Leaving the Moomba Clan
By Gharvin in forum General ChatReplies: 7Last Post: 04-29-2006, 02:27 PM -
Water freezing in my boat??
By Nboard10 in forum General ChatReplies: 8Last Post: 02-08-2006, 11:47 AM -
Salt Water/Brackish Water Use
By RickMcD in forum General ChatReplies: 2Last Post: 06-28-2003, 11:59 PM -
Water in the boat
By Dillon in forum Service & RepairReplies: 2Last Post: 06-03-2003, 06:30 PM
