    Lucas Ohio
    Default new prop questions
    Ok so i keep reading that everyone should have 2 props- I currently only have the one that came on my 08 lsv- Want to buy a back up- I know that there are a lot of diff. types that help/hurt diff. things. I am all about wakeboarding and enjoy surfing and skating. which prop do you guys recomend and how much will it cost me......
    also can someone break down the props and truning- do some make the boats turn better? and it seems like when i put my boat in reverse and turn wheel all the way to left it wont come around. i was warned that wakeboard boats were gonna be tougher in the docks and its really not that hard at all now that im used to it but i just wanna be able to explain to people why when they ask me.
    ________
    gm foods
    Aug 2004
    Lake Hickory, North Carolina
    I think regardless to what prop you use, the boat is going to back up to the right because of the direction of rotation of the engine. Turning the rudder to the left will not help significantly.
    As far as a spare. I'm gonna git me the same thing that's on mine now (one that came from the factory).
    This prolly dint help much, but I tried.
    B
    Pensacola, FL
    Your boat will always back to the right (Nautiques to the left). You have a prop in front of a rudder. In forward, you are pushing water over the rudder making it (the rudder) effective. Even at slow speeds, you don't get much response. The more water you put over the rudder, the more steering you get. In reverse, you are pulling water from the sides of the rudder and not directly over it (unless you go full throttle reverse). The prop only 'grabs' water on the down side of the spin and this is what makes the boat pull to the right; it is called squat. In prop aircraft, it is called P-factor.
    Sep 2005
    Austin, Tejas
    The new XMP prop from OJ is supposed to be a really good one for wakeboarding. It will run you close to $400 plus $100 for a prop puller.
    Lucas Ohio
    thanks for the help guys!
    good explanation max
    ________
    Suzuki GSX650F
  1. considering 05 XLV - some questions
    By tlatoani in forum General Chat
    Last Post: 12-01-2007, 08:38 AM
  2. WAKEBOARD PRO PROP VS STANDARD MOOMBA PROP
    By DMON in forum General Chat
    Last Post: 05-14-2007, 10:14 AM
  3. questions about XLV
    By Jmo in forum Sales & Information
    Last Post: 07-30-2004, 11:29 AM
  4. 03 Mobius questions
    By Kent and Carol in forum General Chat
    Last Post: 10-04-2003, 09:28 PM
  5. Prop questions....
    By wooffman12 in forum General Chat
    Last Post: 08-06-2003, 05:05 PM
