Results 1 to 10 of 37
04-23-2008, 09:54 PM #1Junior Member
- Apr 2008
- 23
Help me decide...Z1 vs Mobius LSV vs Vride!
I drove the Malibu V ride and the Moomba Mobius today. Still need to drive the Tige Z1.
I would appreciate some input from anyone with experience in these boats.
Here are my Pros/cons:
Malibu V ride:
Pros:
Nice ride thru chop
Turns on a dime
Steers super easy and tracks straight at low speed
Swivel cptn chair
Nice storage
Led lit inside gunnels
Awesome tower design
Speedo is digital and adjusts easily with cruise. Holds speed nice.
Cable free throttle...really nice for control
Quiet and smooth
Lift up strut supported storage door in passenger area
Good upholstery and stitching
Warranty??
Cons:
07 I drove was pretty plain and priced at 42k..seems like 08 would be the same?
Manual wedge...please debate the taps, vs wedge, vs adjustable wake plate. I was told the floating wedge messes up handling when its doin its thing.
single axle trailer
Only 4 speakers
Plastic cup holders
No racks
Smallish, but not bad interior, seats 10
08 Mobius LSV
Pros:
All white w/ blk accent was sweet.
Spacious interior
Loaded with tower speakers, dual amps, wakeboard prop,hydraulic wakeplate, Gravity 3 ballast for 42k.
Seems to ride well thru chop, tracks well, quiet.
Nice carpet
Good storage
Rear seat pulls out for rear facing seating
4 year drive train, 3 year bow to stern warranty..due to show special
Cons:
Cable throttle system..seemed harder to control speed.??
Non Swivel cpt chair
Seemed to have more "vibration" initially on acceleration
Front passenger seat access pad squeeks when you lean on it and it opens into cokpit area vs opening up.
Sterring..is it different than the malibu? It seemed like the Malibu was 1 finger steering...??
Tige Z1
Pros:
Sweet looking
Nice area to sit on back of boat to put skis on
Digital speedo? with dial also?
Simple cruise...no look
Storage area opens in bow also, uses shocks.
Taps system...trimable...no need for ballast bags
I can get a smokin deal on one...cant say how much but its almost too good to pass up.
Supposed to ride better in chop, and quieter, with hull design and the way the two halves of boat are fiberglassed together???
Cons:
Seemed tight inside bow a bit, and in main area.
Semi swivel cpt chair
Seems as if dealers are coming and going
Will they be in business for years like malibu and moomba?
Havent driven....soooo
Yamaha 212x...
I dont have enough time..lets say it is out of the running
04-23-2008, 10:22 PM #2
Let me start by saying that I think you will be happy with either of the 3 inboards. After looking at what you said it appears that you are getting a lot more bang for the buck with the Moomba. First, its a 2008. Second, it's loaded. Third, by far the best warranty. Plus at $42k you are getting a sweet deal.
I cannot speak for the other boat companies as I do not have much experience with theme but let me handle some of your cons about the Moomba. Does the LSV have perfect pass or EZ Cruise? It should have one on it at least-problem solved with keeping speed. If you thought it had vibration, try driving it with the standard prop or an acme prop comparable to Moomba's wakeboard prop. For some odd reason Moomba's wakeboard prop makes a strange sound during acceleration at slow speeds. A different prop will fix that. For the cushion, they just have to break in. Also, by swinging out and not up it allows better access for larger items. For the steering, the Moomba should be 1 finger as well. Was it stiff or something?
04-23-2008, 10:25 PM #3Senior Member
- Sep 2005
- Austin, Tejas
- 491
I'm pretty sure the LSV captain chair does swivle but I may be wrong. It also has the Moomba cruise so controlling the speed shouldn't be an issue. Set it and forget it. I do like the Z1 as well but the one I looked at was 60k with the options I wanted.
04-23-2008, 10:34 PM #4
My 07 LSV steering moves with one finger. I agree with the prop. My stock prop felt funny. I changed it and everything is smooth. Think about this, with the Moomba, you get it loaded. With the other boats, it all add-ons. This means big bucks. A friend of mine bought a Master Craft with all the Bells and Whisltes. $95,000 I bought my boat with all the bells and whistles and paid $42,000. See the difference. Hope this helps with your decesion. Plus if you get the Moomba, there is lots of guys that have great ideas, advice, and heplful suggestions.
04-23-2008, 10:38 PM #5Junior Member
- Apr 2008
- 23
Jon,
Thanks..
The boat has ez cruise..just seemed different than the electronic throttle as far as reallllly being able to make fine adjustments.
I am pretty sure its the wakeboard prop...I will ask
The steering seemed stiffer than the vride...maybe break in needed?
04-23-2008, 10:40 PM #6Junior Member
- Apr 2008
- 23
The Z1 is loaded, and they will sell at cost. They are a new tige dealer and want to get the word out, so they said they would think of it as advertising money....I would have to be an ambassador to the dealership...but thats ok....
04-23-2008, 11:41 PM #7
I agree, all 3 are great choices.. You MAY want to pose that question on Wakeworld...You will get strong responses on all three...
One common thing that comes up on the Tige's...... I looked at them myself.. they claim no need for ballast.. boat weight and taps covers that.. Upside...probably less weight for wake/but most wakeboarders claim that it is not enough without ballast... depending on your situation, that may not matter to you... BUT, if you wanna surf, you'll have to add ballast....
Perf Pass can be added to the LSV for about $1000.. Remember that in your comparison. Perf Pass is awesome.. When I had my 04 OUtback, I said, nahhh....no big deal.. when I found my LSV, it had it already and IMMEDIATELY, I fell in love. the LSV is harder to maintain speed than my Outback was with Carb engine (Not using PP), but with PP, not an issue!
You have 3 great boat options now... much better options than the yamaha...
Good luck and the good news is: sounds like your getting an inboard, and soon!Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
04-24-2008, 12:00 AM #8Senior Member
- Jan 2006
- Dallas, TX
- 113
Hey man to me it's a pretty simple decision. I've had a Moomba for 3 years now, and my next boat will be a Moomba as well. Yes the Tige & Mastercraft are quality boats too, but you're simply getting alot less for your money. Tazz mentioned his buddy paid $95,000 for his boat, BUT the boat did not cost an additional $50,000 to make. Skier's Choice does not cut corners to save you money. They are building boats out of a state of the art facility. Basically SC has cut out alot of BS to save you money. Again all the other manufacturers have quality boats too. Just comes down to how much you want for your dollar....To me that's a no-brainer.
GO BIG OR GO HOME!
04-24-2008, 12:04 AM #9Member
- Jan 2008
- Lake Allatoona, GA
- 99
Also, I'm pretty sure the 08 LSV is drive by wire? I was told by a few sources that they had gone to drive by wire. Is that wrong? I swear my LSV doesnt have a throttle cable at the throttle body and just has a wire harness plugging into it. Does anyone know for sure if the 08's are throttle cable or drive by wire?
Mark Miller
2010 Moomba LSV
2008 Moomba LSV - sold
04-24-2008, 12:14 AM #10Junior Member
- Apr 2008
- 23
Tell me how the Perfect pass and the ez cruise differ from each other?
Also, how is that different from the Malibu system?
Can't decide on Mobius V or LSV
By sherardp in forum Sales & InformationReplies: 2Last Post: 11-05-2002, 07:24 PM
