Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Mar 2008
    Brentwood, CA
    Default Our year old LSV!!!
    Well, I finally got around to cleaning her up for the summer so I figured I'd post some pix. I added a heater, sub & amp, and a second battery over the winter. My wife and I just took it out yesterday for the first time this year. So glad I live in California!!!
    The flip side
    Check out the turtles!
    4 Hot-Tubes for the wife and kids!
    2 Batteries, 2 Amps, Charging relay, Switch, Fuse blocks and a lot of wire.
    So proud I had to take 2 pix!
    Upgraded to Polk Momos
    GPS, Sub w/ Flame grill and bass control knob.
    We are eternal, all this pain is an illusion.
    Dec 2006
    Tigard, Oregon
    csmsk,
    Nice looking boat! Did you use a "free air" sub and how does it sound?
    Did you install the heater yourself? I am thinking of doing the same (except a two outlet unit) and am thinking of installing it the compartment under the seat behind the driver's seat like you did. Can you post some pics showing where you installed the heater unit?
    Thanks,
    Al
    Al
    Mar 2008
    Brentwood, CA
    Default Not a free-air - still sounds great!
    It's just an MTX-RT10 sub that I have a pair of from another car. I was thinking that I'd upgrade later, but it sounds just fine being pushed by a Kicker 300.1 amp (200 watts RMS). I've read all the posts about the open-air thing, but this sub really does the lob!
    I did the heater install myself. I mounted the unit where the factory does, opposite the "sub enclosure", accessed throught the front drivers side seat.
    I just put the boat back in storage for the week. I can take more pix on Friday if that'll work for you. Let me know if you have any other questions.
    Dec 2006
    Tigard, Oregon
    Looks good. Did you just run the heater hose up high under the dash and along/under the starboard gunnel?
    What did you use to cut the holes for the heater outlets?
    Thanks,
    Al
    Al
    Mar 2008
    Frisco, TX
    CS,
    I have a sub and amp from my car that I don't use anymore and would love to have it transferred to my boat.
    So, I'm curious how much did it costed you to have the sub, amp, cutting out the floor to install the sub and 2nd battery installed if you don't mind me asking??
    Mar 2008
    Brentwood, CA
    Default Thanks...
    Cab,
    I actually ran the heater hose in the channel under the floor of the drivers side. There are molded "chases" along each side of the boat that you can access by removing the back seat and the v-drive cover box. From there, the drivers side channel goes up to the bulkhead box (or as I call it "the sub box". So if you don't have a sub to pull out and gain access into that box, it'll be tough to pull any hoses through there.
    A 4" holesaw in a variable speed drill did the trick for the Hot-Tubes. Put a few strips of masking tape over the gelcoat where you're gonna drill. Drill a 1/4" pilot hole. Make sure from the back that it'll work there or else re-drill your pilot hole. I had to lower the one under the drivers seat after I drilled the pilot hole and saw that the duct tube wouldn't quite fit that high. So I just drilled a new pilot hole about a 1/2" lower. Then put your hole saw against the tape and drill slowly at first and you can speed it up after the hole gets started. When finished pull of the rest of the tape and you should have a laser sharp edge with no chipping. All four of mine came out sweet!!
    Mar 2008
    Brentwood, CA
    Default Cost of install...
    Hughes,
    I did all the work myself. The only cost was for the different components I installed.
    Sorry I can't really give you an estimated cost for that kind of work cuz I don't know. Try talking to car stereo shops or your local Moomba dealer.
    aewsome amp, sub and speaker setup.
    also luv to see the heater pics as well.
    Murfreesboro, TN
    I love the electrical work.
    That is CLEAN
    It is better barefoot!
    Feb 2008
    Ft. Worth, TX
    A Garmin!?!?!?!?! How big are those lakes California!?
    Texas is a Great Country!
    2008 XLV 1100# sacks X3! Whooya!
  1. new toys this year??
    By moombadaze in forum General Chat
    Last Post: 05-09-2008, 01:16 AM
  2. First ride of the year
    By SEARK in forum Wakeboarding | Wakeskating
    Last Post: 04-28-2008, 08:15 AM
  3. last year to this year
    By SHANE1300 in forum Pride & Joy
    Last Post: 05-29-2007, 10:55 PM
  4. 1st day out this year
    By qb12 in forum General Chat
    Last Post: 04-16-2007, 11:21 PM
  5. Year of model
    By haroldswain in forum General Chat
    Last Post: 07-12-2002, 09:29 AM
