Results 1 to 10 of 11
Thread: Check Engine message.
03-31-2008, 11:22 AM #1Junior Member
- Jan 2006
- Janesville,Wi
- 28
Ok so I got my boat out of storage this weekend. I have been busy gettin everything back in batteries, fatsacs, cushions, etc.
Also the plugs and knock sensors. Well after getting everything hooked up I wanted to run it just to make sure everything was good. It more or less started right up considering it had sat for 4 months. It was a bit rough, but I kind of expected it to be. WEll after about 1 minute I was getting a 'CHECK ENGINE' message. So I shut it down. Checked everything out, found a few spark plug wires that werent quite seated all the way down. Started back up, running smoother, but the check engine message was still coming up.
The engine is a 2007 indmar assault 340(07 supra 21v). All the readings seem normal... temp, pressure etc.
Anyone know if the ECM will clear itself or if a dealer needs to do it? Can I get the message from the ECM without takin it to the dealer?
WE have a big trip planned for the weekend, and the dealer is closed tomorrow so I already lose one day on service. Lauderdale is normally terrific about getting me in and out, but I suspect that they are pretty busy getting boats ready!
03-31-2008, 12:50 PM #2
It is my understanding that if you cycle the motor 3 times w/o a failure, it will reset.
Crank, run to operating temp. shut down and let cool completely.
Do this 3 times and you should get there.
This is what I have been told is the manner reset without the ECM...
Try 1st before taking to dealer..Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
04-01-2008, 03:06 PM #3Junior Member
- Jan 2006
- Janesville,Wi
- 28
Got it out to Lauderdale today and they took a look at it immediately. It is just a 'pedal position' error and should be able to have her back by tomorrow!
04-01-2008, 05:09 PM #4
Glad to hear your going to be up and running quick.... What did they say about the engine code? I think I heard it will clear after 20 key ups if it is just an error that goes away. But if its something that continues if wont clear. Check all fluids and watch temps real close but okay to run it back to dock if your out a ways??
04-02-2008, 07:19 AM #5Junior Member
- Jan 2006
- Janesville,Wi
- 28
They said it was a 'pedal position sensor' failure. They tried replacing the sensor and the code was still there, so then they cleared it and it is not coming back up. I hope that is my only hiccup for the year.
Yes apparently if it is something serious, the engine will go into 'limp' mode, and let you limp back to the dock.
ALthough, driving back home from the dealer, the tower leg release bolts vibrated all the way out on one side and the leg dropped onto the boat, put a pretty nice gouge in the gel/fiberglass.
I guess this is my own fault though as I hadn't checked them out yet. Hadn't been on the water yet so hadnt event though about it.
04-03-2008, 06:25 PM #6
G- I'm sorry to hear that. I lost 1/2 of a quick release knob in the water - it was a good lesson and I've since always checked them at the ramp but now I'll be checking before l leave the driveway. By the way AWS has replacements.
07 LSV
If you can't fix it with a hammer you've got an electrical problem!
04-03-2008, 09:41 PM #7
My 2007 also had a bad pedal position sensor. I noticed one day that I was having to work hard to hold speeds. Any correction I made was either totally ignored or over done.
It turned out to be my only issue with that particular boat.
Good luck!2008 Outback
325 EFI
Gravity 1 Ballast and Multi Sport Wake Plate
Rad-a-cage
OJ 4 Blade 13x13 Prop
5 Seasons pulling the Ski Team and still going strong!
04-03-2008, 10:07 PM #8Sled491 Guest
GM, are you talking about Laurderdale Lakes Marine in WI?
04-04-2008, 09:27 AM #9Junior Member
- Jan 2006
- Janesville,Wi
- 28
Yeah... Lauderdale In Elkhorn Wisconsin.
Their service dept is top notch! Marty and guys always get me in and out!
04-04-2008, 10:46 AM #10
Sorry G - I was thinkin you were in the Portland Or area that's why I directed you to AWS. You'd be going about 4000 miles out of your way to pick up a knob there - probably not worth the drive!
07 LSV
Message to NH Moomba
By plumcrazy in forum Boat OwnersReplies: 8Last Post: 04-21-2005, 09:12 PM -
Something to Check!
By BOOM-BA in forum Service & RepairReplies: 2Last Post: 08-17-2004, 07:12 PM -
Skier's Choice fix your message board!
By waterboy in forum General ChatReplies: 8Last Post: 02-17-2004, 01:21 AM -
message board troubles
By skibohdi in forum General ChatReplies: 1Last Post: 02-16-2004, 11:32 AM
