Results 1 to 3 of 3
Thread: Light bar
03-16-2008, 08:37 PM #1Member
- Jan 2008
- Atlanta via Pittsburgh
- 93
Light bar
Hi All, I'm trying to get some specs on the new moomba LSV tower. I found a light bar on ebay for a pretty good deal but I can't figure out if it will fit. Secondly I can't find specs on the tower diameter to decide which clamps to get. Lastly, I would like to be able to control the front and back lights independently. Any sugguestions??
ThanksGo Boat
03-16-2008, 10:08 PM #2
Chillyx--
Most manufactured light bars are wired so that all the lights come on the same. I emailed you about my light bar. You can rewire the bar. It should not be that hard. The two side pieces can be removed so access the wire. If you have a double accessory switch, this can be done. You will need two 4 wire bosh relay. One relay for each set of lights (front and rear)
Hope this helps.Tazz 07' Moomba LSV --Kicker Marine Amps (MX700.5 & MX350.4) 6 polk DB651 speakers, 4 MB Quartz Marine Speakers, 10" Boston Acoustic Sub, Z-5 Cargo Rack, Custom Speaker/Light Bar, modified ballast system, Custom LED Rings
03-16-2008, 10:42 PM #3
Chily,
2 3/8" is the tower sizeBrad
2006 Moomba Mobius LSV sold
2004 Outback sold
Light Bar
By tazz3069 in forum Moomba ClassifiedsReplies: 8Last Post: 03-21-2008, 09:29 AM -
Installation of light bar
By mobyatBelews in forum General ChatReplies: 1Last Post: 09-30-2005, 02:43 PM -
Light Bar wiring help
By amonteroman in forum Service & RepairReplies: 1Last Post: 08-02-2005, 09:55 AM -
WakeBoard Light Bar
By jekvall in forum Wakeboarding | WakeskatingReplies: 2Last Post: 07-07-2004, 06:57 PM -
Tower light
By Shawn in forum General ChatReplies: 4Last Post: 01-10-2004, 05:10 PM
